Old 10th November 2008, 01:19 PM   #1
Default Video Switching
I need to switch either one of two composite video inputs to a single output. Plan to use a PCB mounting relay. Can anybody suggest a better solution using solid state devices.
premkumar9 is offline
Old 10th November 2008, 01:58 PM   #2
Depends what you mean by 'better', a relay works absolutely perfectly, any electronic solution is far more complicated, and lower quality.
Old 10th November 2008, 02:02 PM   #3
Better considering cost, signal quality and reliability.
Old 10th November 2008, 02:04 PM   #4
A relay is probably better on all three.
Old 10th November 2008, 02:08 PM   #5
Cheap too. Use a SR relay and it'll draw zero current once switched.
Bill
Smart Kits build Smart People
Old 10th November 2008, 03:42 PM   #6
Can I drive many relays (switching ON simultaneously) using single transistor and flywheeling diode OR separate transistors required for each relay?
Old 10th November 2008, 03:43 PM   #7
What is that relay? Your site is still down?
Old 10th November 2008, 03:53 PM   #8
Relays have perfect differential gain and phase, low crosstalk, and low noise. However, if you want to switch between synchronous sources and not see the switch on the TV screen, relays suck. Our OP hasn't said what his application is. If it's just for home use, relays should be fine.
Ron
Roff is offline
Old 10th November 2008, 04:48 PM   #9
Yes you can.
Old 11th November 2008, 12:36 AM   #10
Default Increasing output
I have one more doubt. I attach audio and video distribution amplifier circuits for driving three 75 Ω load. Can I increase it to 10 with the same circuit configuration by changing the componentss to higher rating? I
Old 11th November 2008, 01:31 AM   #11
Have a look at Linear Technology's LT1206 and LT1207. These parts are challenging to use, but strict adherence to the datasheet regarding feedback resistor values, power dissipation, heatsinking, supply decoupling, etc., will pay off. You should be able to drive ten 150 ohm loads with either part.
Ron
Roff is offline
Old 12th November 2008, 04:10 AM   #12
May be possible to make the required amplifier with those ICs. But in my case due to some reasons I wanted to know whether 10 O/P can be driven by changing the output transistors. if so, wanted to locate transistors which give satisfactory result with out affecting band width. Of course I can experiment and find out. But wanted an expert opinion for saving time and effort.
Old 12th November 2008, 04:33 AM   #13
It would be difficult for me to predict without breadboarding or at least simulating with different transistors. The ones specified are already pretty substantial. Higher power transistors in general have higher capacitance and lower Ft, both of which are detrimental to bandwidth.
Ron
Roff is offline
switching, video
Video Amp circuit for Component (RGB) video rayyolanda Electronic Projects Design/Ideas/Reviews 9 6th September 2008 09:47 AM
Video Baluns (video over cat 5) Mustang Datasheet/Parts Requests 5 25th June 2007 11:27 AM
Video -> Binary -> Video TiagoSilva Micro Controllers 14 9th March 2007 04:01 PM
Why switching ? grandestlama Electronic Projects Design/Ideas/Reviews 5 17th October 2004 09:13 AM
Composite video to s-video converter thecableguy007 General Electronics Chat 6 17th September 2003 04:01 AM
