Old 23rd October 2008, 08:57 AM   (permalink)
Default How to connect a trimmer capacitor
i am trying to connect a trimmer capacitor on breadboard. but the trimmer has three pins. I know that two of the pins are connected together. does that mean I can choose one of the two connected pins as one plate of the capacitor and left the other pin as floating?
the trimmer looks like this:
macnl is offline
Old 23rd October 2008, 10:31 AM   (permalink)
Say you number the pins so that the nearest (on the picture) is pin 2, the rightmost pin is number 1 and the most further is 3.
The capasitance between 2 (middle pin) and 3 will increase when you screw it clockwise. I think the capasitance between 1 and 3 will be constant.
Grossel is offline
Old 23rd October 2008, 10:37 AM   (permalink)
Yes to your question.
The trimmer has a continous rotation, watch the trimmer vanes as you adjust the capacitance
when using a 'non metallic' trimming tool.
Old plastic knitting needles filed down to a blade, make a cheap tool.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 23rd October 2008, 10:50 AM   (permalink)
It has three pins for better mechanical stability. Since it is adjustable it could twist lose on a PCB having just two pins.
Boncuk is online now
Old 23rd October 2008, 03:56 PM   (permalink)
I followed the links from the properties of the picture you posted and found these datasheets:
http://www.rapidonline.com/netalogue/specs/12-0100e.pdf
http://www.rapidonline.com/netalogue/specs/12-0110.pdf
They clearly show the pin connections for two different size trimmers.
Ron
Roff is offline
Old 23rd October 2008, 04:55 PM   (permalink)
I haven't tried inserting a trimmer on to a breadboard. I usually use extra wires with the legs to easily insert into the breadboard.
Likes to have some rare,nostalgic transistors for my breakfast...
rahulan999 is offline
Old 23rd October 2008, 05:07 PM   (permalink)
A breadboad has more capacitance between all its connections than the trimmer capacitor.
The trimmer capacitor is used in high frequency RF circuits where a breadbard doesn't work and should not be used. Use a pcb.
audioguru is offline
Trimmer caps zachtheterrible General Electronics Chat 5 4th September 2004 07:11 AM
Trimmer SnaRf General Electronics Chat 3 24th December 2003 01:24 PM
Trimmer Capacitor lead size daviddoria General Electronics Chat 4 26th January 2003 10:02 AM
trimmer capacitor value daviddoria General Electronics Chat 4 8th January 2003 12:33 PM
Trimmer capacitor values!? hantto General Electronics Chat 2 7th January 2003 08:12 PM
