I just bought two different boards, one is white breadboard and the other is board with copper hole that don't connected to each other. (I don't know the name) I understand how the white breadboard works. but how does this board work? °°°°°°°°°°°°°°° °°°°°°°°°°°°°°° °°°°°°°°°°°°°°° °°°°°°°°°°°°°°° °°°°°°°°°°°°°°° °=hole in the board. Can someone point me to good site explaining how to make circuit using this kind of board. TQ.
__________________ There's if in L.I.F.E | |
| | #2 | |
Do you mean this type of pcb.? http://www.electro-tech-online.com/a...r-up-7seg2.jpg
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
That is a general purpose board and will not help much because after inserting the components into the holes, you will have to use either the component leads itself or separate wires to make interconnection in between them - more chance of short circuits. I suggest you to use a stripboard and use a razor to cut the unwanted connections. That will reduce the task anyway. From Schematic to Veroboard
__________________ Speaking from vacuum.. | |
Yes, how do you make connection with that kind of board? Tq
| Look at the the link I posted in my previous reply, the link shows how its done.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 23rd October 2008 at 10:04 AM. | |
| | #6 |
I have actually used that board by connecting adjacent holes with solder. Because the holes are quite close as long as you apply a little more solder than normal it is easy to bridge connections.
| | #7 |
Tq All For Helping!
| | #8 |
Hi Rumieus, I use this type of board with #28 or #30 Kynar wire-wrap wire for the connections. It's a very time consuming process and it takes some practice but it does work. Good luck. Mike Last edited by Mike, K8LH; 24th October 2008 at 04:39 AM. | |
| breadboard |
| The Breadboard | ElectroMaster | Electronic Theory | 22 | 15th October 2008 02:51 AM |
| Breadboard-like sockets? | ArtemisGoldfish | Datasheet/Parts Requests | 5 | 8th June 2008 02:27 PM |
| Where can i get one of these? ISA Breadboard... | Marks256 | General Electronics Chat | 4 | 13th April 2008 07:40 PM |
| Breadboard Query | UTMonkey | General Electronics Chat | 9 | 30th December 2007 02:28 PM |
| Using ICs on breadboard | daviddoria | Electronic Projects Design/Ideas/Reviews | 3 | 25th February 2003 06:30 PM |
