Old 23rd October 2008, 05:31 AM   #1
Default 9V Battery Backup Relay
Are there any solid state options available for a simple relay for a 9v battery backup?
Power to the device will be DC +5V. If this voltage drops below a specified level, say 2.5V, a relay should switch to a 9V battery backup (with a voltage regulator, of course).
I've done some searching but I'm having trouble coming up with something like a part number or datasheet.
Thanks!
bacterozoid is offline
Old 23rd October 2008, 08:32 AM   #2
Thanks!
Look at using blocking diodes when connecting the two voltage sources in parallel.
Do you follow OK.?
ericgibbs is offline
Old 23rd October 2008, 12:01 PM   #3
So a blocking diode has a higher current rating than a normal diode and will block current flow when one side has a higher voltage than the other?
So if I have 5 volts on both sides (one Vcc and one the regulated 9V), and I put a blocking diode in series with the backup and then connect the two sources in parallel, the 5V backup source will be enabled when Vcc drops below 5V?
Old 23rd October 2008, 12:09 PM   #4
Assume that the current required by the load is less than 1A.
By connecting a 1A diode [1N400x] from the +5V to the load will give approx 4.7V at the load.
Do the same for the output of the regulated +5V, that is connect a 1N400x diode in series with the 5Vreg out and the load.
Post a sketch showing the basics on how the 5V and the 5Vreg are going to be used and I will draw in the diodes..
Old 23rd October 2008, 12:24 PM   #5
I've got more than a sketch
Old 23rd October 2008, 12:41 PM   #6
Look at this cct.
This is the BAT54
STMICROELECTRONICS | BAT54 | Diodes | Semiconductors - Discretes | Farnell UK
Old 23rd October 2008, 12:54 PM   #7
Ok, so in your circuit, when Vdc is operative at anything above 3.9V the diode will be forward biased and out goes the voltage.
When it drops below 3.9Volts, the BAT54 becomes reverse biased and 4.3 volts comes down from the regulated source?
Old 23rd October 2008, 01:03 PM   #8
No, the 5V will supply the load until the cct voltage drops to 4.3V, then the +5Vreg [9v] will supply the current to the cct, the voltage being 4.3V.
The 1N4001 is reversed biassed when the cct voltage is greater than 4.3V.
Old 23rd October 2008, 02:17 PM   #9
A 9V battery cannot properly power a 7805 regulator. The regulator needs a minimum input of 7.5V but the voltage from a 9V battery quickly drops to 7.2V then drops slower to 6V.
Use a low-dropout regulator that will still provide a regulated 5V when its input is as low as 5.5V.
audioguru is offline
Old 24th October 2008, 12:36 AM   #10
A 9v battery should work fine. I have built many test modules using a 7805 regulator with no problems.
"Remember, you're special.....just like everyone else."
rezer is offline
Old 24th October 2008, 01:08 AM   #11
t the datasheet for a 9V alkaline battery. Its voltage quickly drops to 7.2V.
Look at the datasheet for a 7805. it is spec'd with an input of at least 8V. Its dropout voltage is typically 2V but could be higher. When it has dropped out then it is not regulating.
Old 24th October 2008, 02:14 AM   #12
An LM2940-5 is a low dropout replacement for the 7805
Bill
Smart Kits build Smart People
Old 24th October 2008, 05:29 PM   #13
A relay with a 5v coil will probably drop out at 3v. If this is close enough to 2.5v, and relays with 5v coils can handle your current draw requirements then hook up the relay contacts so the 9v batt/reg arrangement is switched in when the relay drops out.
Willbe is offline
Old 24th October 2008, 05:33 PM   #14
Thanks for all the suggestions guys. Analog electronics aren't exactly my strong point so I appreciate the help!
Old 24th October 2008, 07:25 PM   #15
I understand that and I'm sure what you are saying is correct. I'm only speaking from my own experience with these devices.
rezer is offline
backup, battery, relay
battery backup johnsmith123 General Electronics Chat 5 18th July 2008 08:25 PM
Battery backup maxmanclive Electronic Projects Design/Ideas/Reviews 10 19th September 2007 07:33 PM
Battery backup with charger Ckt yagtoby General Electronics Chat 1 9th July 2007 06:15 PM
Battery Backup gregmcc Electronic Projects Design/Ideas/Reviews 3 29th June 2007 12:49 PM
battery backup for PIC AndyWatson Electronic Projects Design/Ideas/Reviews 18 27th October 2004 01:00 AM
