Old 10th April 2004, 12:09 AM   (permalink)
Default Bi-directional cable line amplifiers
I just purchased a 1 input 4 output bi-directional cable 8 Db amplifier to improve my cable internet connection and picture on my television. I already have a 14 Db amplifier(bi-directional 1 to 1) for my main television. The combination of these amps gives a bad picture quality. To expirement I then took the 14 Db amp and put the input cable(source) into it. I then took the output of that and put it into the 8 Db amp input. The output of the combination was decidedly horrid. It was more snow than picture. Why does this happen? Is there any way i can use the 14 Db amp to improve anything? Thanks
Doofmaster924 is offline
Old 10th April 2004, 01:02 AM   (permalink)
Just guessing here but the 1 to 4 splitter is designed to be a distribution amp and not a point amplifier. That and the fact that You cascaded the amps means that the TV is not only being overdriven, but they also amplify noise as well as signal. If you have a picture problem notify the cable company.......unless it's an illegal tap. In that case put the amp at the feed side not the TV side, and try to find an amp that has a variable gain that you can fine adjust.
TillEulenspiegel is offline
Old 10th April 2004, 01:33 PM   (permalink)
You should not need an amplifier on the cable line, even with a passive 1:4 splitter, there should be enough signal to give a good picture. There must be a problem with your television.
Russlk is offline
