Old 4th April 2004, 07:49 PM   (permalink)
Default resistor
i am running 2 x12volt dc motors @ 600ma each ( but not at the same time)the battery i am using is a 12 volt 7 ah with a 240 volt dpdt switch for an on/off switch. as i am using the 2 motors the switch is getting very hot so i was thinking do i put in a resistor somewhere if so where and at what value
thanks for any call back
oakmeadows is offline
Old 4th April 2004, 08:23 PM   (permalink)
Default OHMS LAW!!!
It is simply Voltage=Current*Resistance
So if you want to drive one motor at a time it is:
12v=0.6*R
R is then equal to 20 ohms
What is the power rating of your switch??
Best Regards
Asjad is offline
Old 4th April 2004, 09:15 PM   (permalink)
Default resistor power
be careful, you may need to watch the power rating of your resistor.
The standard 1/4 W will not do
get 1-2 Watt resistor, and do the touch test to see if starts to cook!
Best Regards
Asjad is offline
Old 5th April 2004, 01:54 AM   (permalink)
Default Re: resistor
You may want to consider something like using a switch with higher power rating or get one with several contacts that you can parallel to reduce the stress on each single contact. This is more efficient than burning watts in a resistor to relieve a switch contact.
Optikon is offline
