Old 23rd March 2004, 07:53 PM   (permalink)
Lac
Default Can't find 60Hz Oscilator!
I'm about building a digital clock, and I have read that I need a 60Hz Oscilator, but I cant seem to find oscilators that low! Every oscilator is rated in MHz not Hz. I only find 60MHz , do the producer mean that 60Hz and 60MHz are the same? Can I use a 60MHz oscilator instead?
Thanks!
Lac.
Lac is offline   Reply With Quote
Old 23rd March 2004, 09:00 PM   (permalink)
Lac
hmm.. but what if I buy a clockcrystal (32KHz) and then buy 5 decade counters and then devide the frequency down to 1Hz? (32000/10/10/10/4/8=1Hz) weird idea , but will it work?
Thanks!
Lac.
Old 23rd March 2004, 09:59 PM   (permalink)
That is the way to do it, but you can do it with one binary counter and some decoding.
Russlk is offline   Reply With Quote
Old 23rd March 2004, 10:02 PM   (permalink)
What You need exactly 60Hz or 1Hz? Some alarm clock chips need 60Hz clk freq. 60 MHz (or 6 or 3MHz) quartz and decade counters is a good choice. 32768kHz Xtals most of case cheap, but low quality.
Sebi is offline   Reply With Quote
Old 24th March 2004, 02:46 PM   (permalink)
Lac
Serious? Is that the way to do it? buying 5 decade counters and devide it down? But I have limited space for the chips (ca. 2x2") aren't there any other way to do it?
These chips wil drive 4 LED-Displays that contain 4-6 elemts each. So they will drive ca. 16 displays ( four digital clocks that run simously.)
Old 24th March 2004, 03:01 PM   (permalink)
You should get an ic like the CD4060...
udi_hakim is offline   Reply With Quote
Old 24th March 2004, 03:10 PM   (permalink)
Lac
What about this one then?
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4226
Old 24th March 2004, 04:31 PM   (permalink)
Interesting chip, but cannot produce 60Hz....
Old 24th March 2004, 05:50 PM   (permalink)
Lac
Output Frequencies Independently Programmable from 0.25Hz to 1.048MHz
Can't it?
Old 24th March 2004, 08:26 PM   (permalink)
one hz is a possible output but not 60 hz.
Old 24th March 2004, 09:30 PM   (permalink)
Lac
why?
What about using a 555timer IC? but I can't seem to figure out wich combination of resistors and capacitor to use to get 1Hz output. help?
Cheers!
Lac.
Old 24th March 2004, 10:39 PM   (permalink)
Or use a MM5369 IC as the 60 Hz source, these are very accurate and use a commonly available 3.58 Mhz TV colorburst crystal.
Two roads diverged into a woods...i took the one less travelled by. R. Frost.
nettron1000 is offline   Reply With Quote
Old 24th March 2004, 10:41 PM   (permalink)
For a stable 60 hz use this circuit:
Old 24th March 2004, 11:17 PM   (permalink)
It would work, but wouldn't be very accurate - a free running oscillator isn't much use for a clock! (think + or - one hour per week!).
Old 28th March 2004, 07:00 PM   (permalink)
if you live in the states, you can get the 60Hz from the outlet. edison doesnt guarantee 120V, but they do guarantee 60Hz. with a bit of circuitry, you can get a 60Hz squarewave. if you live in an area that supplies 50Hz, then perhaps a 555 timer with a trim pot would work for you. some companies used to have 60hz time-base generator ic's. may have discontinued them. perhaps you can find a place that specializes in hard to find ic's.
What\'s the worst thing that can happen?
DemonRising is offline   Reply With Quote
