| hi all, how do i add a current limit to an already built power supply? this power supply has current of up too 2A and 30V. i want the current limit to be able to reach 50mA to 2A.... thank's
__________________ Do not say you don\'t know, say you don\'t want to know! | |
Any external circuit will require a device to pass the full current, and large heatsinking as well, plus it will drop some voltage and reduce the regulation of the output voltage. | ||
| it's not yet built... basicly it's a double PSU that uses the LM317T regulator, the schematic below shows one of the LM317's.... the Pot. is 5.5K
| Download datasheet for LM317T. There is an example of regulated power supply with current limiting (uses additional 317 for current limiting). | |
| i looked there, but isn't there something simpler? plus i can't find those FET'S anywhere.... and inserting a negative voltage is not an option too... any ideas?
Assuming you're wanting to build a nice versatile lab PSU, I would suggest dropping the 317 and building something more complicated - perhaps using a 723 IC and external transistors, there are loads of designs about. | ||
| after snooping around a bit i think i'll take your suggestion, but i think i'll build this one. is it a good PSU? http://www.electronics-lab.com/proje...011/index.html
| but would you recomend this one? or is there something better, yet simple enough? the problem is that there are going to be high-school kids working on this (one's that don't understand much... :-) ) so i need to make it fail-safe... any suggestions how should i improve this circuit (other than adding a fuse..hhh)?
A fuse would be a good idea, and probably having the mains transformer in a separate box (where the kids can't touch it) would be a good safety idea as well. | ||
| yes, as always you were right, this will be for the use of the school... i need to build a double power supply, so i assume that i just share the output of the transformer with two of the circuits? another thing is the cost of the transformer... do you know a web site that sells these cheap? and ship internationally?
| | (permalink) | ||
Also, don't forget, you will need substantial heatsinking on the output transistor!. | |||
| thank's, but i think i'll stick with one transformer due to the price and the fact that i can't get an 220/2x24v transformer... electronics is a funny buisness... i tried to make the cheapest power supply and the price of the material's for each one climbs up to 33$ not including the PCB and box....
