| Hi, I am using HP pavilion 8802 with Windows ME on it. I want to set a password to protect others from using it. (Computer should not be on with out a PW) Can any one give me the idea. Thank you very much. Mahinda | |
| BIOS boot passwd | |
| agreed, thats the only way with a non NT based win OS
__________________ thanks, david | |
| that sounds best but, some motherboards have an intrusion alarm, so the cmoputer locks up if the case is opeoned (it is usually just two pins on the mothboard, that you are supposed to connect to a microswitch or similar) which usually have a jumper over them. I don't know about all of them, but I know on my motherboard, if the jumper is removed (simulating the case being opened) the computer won't boot up. you could connect these pins to a key switch, or a kepad device... advantage over bois pasword? probably none, but what the hey. Tim | |
| How do I get in to bios. I am using "HP pavilion 8802: win Me on it. I remembered need to press 'Del" key when booting some comp What keys need to press on mine. Thanks. Mahinda | |
| different comps use differnt keys. I dont know what key mine is I just knwo it is exiter F2 or DEL so it press both at boot try F1 or F2 or DEL they are the common ones | |
| You need to hold down the DEL key while your computer is in booting stage ( not when the Win logo appears ) . | |
| ricky, it very much matters which type of motherboard he has as to which key to press (not hold) ESC, F1, F2, F10(compaq), F12, DEL those are the only ones i've ever seen david
| Yes, It is "F1", By pressing I can go to BIOS. But I could not find any option to set PW. Any idea. Thanks | |
| pls press del when u r starting u'r windows, after that u will find bootup paasword, with that u'r problem will be solved( i think). | |
| Bios Passwords Of desktop COmputers Are Pretty useless, Just Open The Case And Take The CMOS Battery Out. If The Case Has a Lock On it, Just Cut It with a portable Dremal :cry: lol | |
| equally just remove the HD plug it into anothe rcomp and remove the date. Boot of a linux floppy, access the registry and reset syskey to access NT/2k/XP windows systems with an adminstrator passwd THere is no security that cannot be bypassed with enough time and tools. I think he is after something to stop the casual user from booting and messing with stuff | |
| If the OP is looking to slow or stop the casual user, and is running Win9x or WinME, the is a fairly easy way to do this. Of course, as has already been posted, there is no foolproof method of protecting the files on any PC if the invader is serious about getting in. Between software tools to crack passwords and hardware tools to remove drives, it's pretty hard to stop someone who really wants in! That having been said, Robert's Shutdown Security is an excellent way of adding and enforcing password security on a PC using a version of the Windows operating system that is otherwise wide open to the unauthorized user. This utility, when installed and active, will allow the system to boot to the desktop only if the user name entered is on the approved list of users, and if the proper password associated that user name is entered. Pressing the Escape key, entering an unauthorized user name, or inputting a wrong password will all return the user to the login screen. I have long used this utility for teachers in classroom settings who have the need to keep their students out of the teacher workstation. It worked nicely on Win95, and still works nicely all the way through WinME. Of course, the more secure versions of Windows -- WinNT, Win2K, and WinXp don't really need anything like this if their security options are properly set. | |
| I want to protect my PC from kids. That is the reason to set the PW. When booting the PC, I can go to BIOS by pressing F1 (not Del key ). Any further ideas. | |
