Old 7th March 2004, 08:28 AM   (permalink)
Default Interfacing RS232 buffer with MSComm
Hi guys,
I face some problem on using MSComm ....
I want to send a byte of data to the RS232 buffer and the data
received is the Hex of the sent data. After trying for few times,
I get weird Hex numbers....
Is it my program problem or the hardware ??
the following is my program.....
Private Sub end_Click()
MSComm1.PortOpen = False
End
End Sub
Private Sub Form_Load()
MSComm1.PortOpen = True
End Sub
Private Sub receive_Click()
Dim InByte() As Byte
Dim buf$, i%
InByte = MSComm1.Input
For i = LBound(InByte) To UBound(InByte)
buf = buf + Hex(InByte(i))
Next i
txt2.Text = buf
End Sub
Private Sub send_Click()
Dim a As Integer
Dim OutByte(1 To 1) As Byte
'For a = 1 To 100
OutByte(1) = &H1F
MSComm1.Output = OutByte
'Next a
End Sub
wingbar is offline
Old 7th March 2004, 06:13 PM   (permalink)
Try this code:
End
End Sub
End Sub
Dim InByte As String
Dim i As Integer, buf as string
For i = 1 To Len(InByte)
buf = buf & Hex(asc(mid(InByte,i,1)))
Next i
txt2.Text = buf
End Sub
Dim a As Integer
Dim OutByte As string * 1
OutByte = Chr(&H1F)
'Next a
End Sub
Check your baud rates properly.
kinjalgp is offline
Old 9th March 2004, 05:41 PM   (permalink)
thanks ...
I am able to send and receive back my data through RS232 buffer but after i connect all my components, the only response i received back is FFhex when I send a byte of data from the range of 70hex to 79hex.
From the info i got, it said that to send data to the write buffer, I need to send 0X to 5X hex, where X represents the data I want to send while 0 to 5 represent each write buffer. And if I want to read back the data, I need to send 70,71 and 72 hex.
My question is, is it true that I need to send some specific codes to be able to read and write from the buffers ? If so, why ?
wingbar is offline
Old 9th March 2004, 06:17 PM   (permalink)
I am not sure I follow what you are saying.
To receive data on the serial port all you really need to do is use:
Private Sub MSComm1_OnComm()
 Dim InByte() As String
 Dim buf$, i%
 Next i
 txt2.Text = buf
End Sub
Instead of having a button receive, when you click on it. Also all data you get is a string data...... You are sending and receiving ASCII characters. How you interpret them is upto you. You can make them the ASCII value by using the ASC(string) function, then if you like you can change that number to HEX if that is how you want to display it.
What are you trying to communicate with... or what is sending this 5X data?
Ivancho
ivancho is offline
Old 10th March 2004, 12:45 PM   (permalink)
Originally Posted by wingbar
thanks ...
Are you working with some specific device?
kinjalgp is offline
Old 11th March 2004, 06:30 AM   (permalink)
sorry for not writing my question clearly...
Actually I'm doing a chip tester project. my hardware is connected like this :
RS232 buffer <----> UART <----> Decoder <----> Buffer <----> Socket
-The decoder includes input address and data decoder, Buffer includes Write and Read buffer and the socket I use is the ZIF socket.
From the info I got, I need to send some hex numbers to write my data in the appropriate write buffer while to read the tested result from the read buffer, I need to send 70 to 71Hex.
So, I'm wondering if it is because of the IC of the buffers?
wingbar is offline
