| i now have a working 555 yay! ok so now i am connecting 8 and 13 of th 4017 to ground, 14 to 3 from the 555, 16 to Vs, and led to pin 3 - then to ground, and pin 2 to 15 to reset it after 1 output. is there anything wrong with that? i'm going to try to draw it for you in my new software http://www.bandtank.com/~calculusap/oscillator.ewb that looks pretty crappy... how do you make the lines not go through stuff?
__________________ thanks, david | |
| Congrats! Sorry I couldn't get your Elect. Workbench file but your description sounds fine. Move that pin #15 connection up a bit, add some LEDs, and turn that 4017 loose to run. I appreciate your posting as so many people ask a question and never reply. You never know if they ever came back and read the replies - strange. | |
| haha. so i can't seem to get the LEDs on the counter to turn on..... i am going to go try a transistor now... but i thought the output of the counter was enough to turn on an led... if that doesn't work i'll post again to see what else i can do. thanks david
| Since I can't see your circuit, I don't know what your power source is but a 555/4017 powered by a 9 volt battery should produce about 5 volts at pin 3 of the 4017 (plenty to burn out an LED without a dropping resistor). Maybe you could PM me with your .ewb file as an attachment - don't care if it's crappy. I am assuming from your first post that you have confirmed a pulse comming from the 555 - check your connections. | |
| hahahaha i got it!!! gene, again i'm almost sure i saw that the 4017 has internal ouput resistors... i'll try to find it again. my problem was simply with how i was connecting the leds to the breadboard. they were shorting themselves! i'll be darned! well it works now, time to put it on a protoboard i'll take a video and send you when i'm done (might be a couple days) thanks a million! david
| The 4017 has a current limitinng circuit which is marginal-at-best for operation at 5 volts. You can also limit the output by connecting the input pulse through a resistor. The easiest way is to connect your LEDs directly to the output pins of the 4017, tie the (-) side of the LEDs together, and run that through one resistor to ground (this is ususlly possible since only one LED is lit at a time). There is no need to do the video for me - just glad you are up-and-running. BTW, before you solder the thig up, now would be a great time to experiment with the different functions of the 555 and 4017 (pulse timing, timing vs. astable operation, reset after different counts, and cascading multiple 4017s). Enjoy! | |
| again thanks soooo much. indeed that is an excellent idea. i was actually planning on throwing another 4017 in there to get them to go backwards as well just to see how to do it david (just in case http://www.bandtank.com/~calculusap/lights.wmv
| great work.....working fine! | |
| only one more question! i got this working several times now, that means i understand, yay! i am using Trax Maker to draw. I noticed that on my 4017, there is no pin 8 and no pin 16. these are Vs and ground. when i hit "simulate" it doesn't work (i'm guessing because the chip isn't getting power) i also noticed on a drawing by kinaljp that he was missing the same pins... is there a way to add pins? are they left off for a reason? david
