| I am a novice in electroincs with a question about powering two small devices. The specs are 14 amps and 9 volts on one and 9 amps and 15.4 volts on the other. I am guessing that I need an AC to DC power supply. But what do I need to look for when I buy it? Is this range of power standard? Thanks | |
| 14 and 9 AMPS are very high currents. No doubt you'll get power supply of this rating in the market but be sure of what you are doing because short circuit @ 14 amps can easily cause fire. Are you aware what are those 2 devices?
__________________ "There is no way to peace, peace is the way!" | |
| when you say 14 amps and 9 amps is a lot, can you give me a comparison to some other items and their currents. For instance, an item with low amps and an item with amps comparable to the 9-14 range | |
| But before that I would like to know what are those 2 devices which requires such high current.
| sorry about that. They are cooling devices (TEC's) | |
| When I said high current, I compared it with currents in electronic circuits which are generally of the order of few hunderd milli-amps or sometimes few amps except for power amplifiers. So I was wondering which device is eating so much of current. The best suited power supply would be SMPS as even a compact sized PS can cater considerable amount of current.
| Can you tell me more about SMPS? What is the price range for something like that? What else would I need as far as fuses or other? Also more about any possible safety concerns. I really appreciate all of your info. Thanks. | |
| SMPS (Switch Mode Power Supply) is a kind of PS similar to one used in computers. As compared to bulky transformers it is quite compact and has many other featutes too like good output regulation, less ripple etc. I don't have idea about pricing of SMPS of 14A and 9A but a computer SMPS will cost you around US $10 which has a 12V output capable of giving 10A and 5V @ 25A. Regarding safety, a fuse is always good to use whose capacity will depend upon your load current requirements.
| Where can I buy a SMPS and how is it powered? What else will I need to be able to adjust the voltage and current that it outputs? | |
| Well, a normal computer SMPS is available in any computer hardware shop. It is powered from AC mains 110V/220V. Normally the outputs of SMPS are a fixed voltage but by changing the component values you can vary it.
| See this post if you want to see how a computer's SMPS look like: http://www.electro-tech-online.com/viewtopic.php?t=730
| Thanks for all the info. I really appreciate it. | |
| An example might be a car brake light which pulls about 2 Amps - about the same as a 27" color TV. Of course the TV is AC and that's a different situation but hopefully this will give you an idea of how hot 14 Amps is - please be careful. When you said powering "two small devices" and then said 14 Amps, something didn't sound quite right. Could it maybe have been mA (mili-Amps)? | |
| It is a cooling device and I have learned that electric heating and cooling devices can use very high current. I would like to learn more about any precautions I should take or any pointers on how I should setup the initial testing of this device. If you have any thoughts on this I would appreciate it. | |
| Since you got everyone's attention with the high current thing, you should simply be sure to insulate all connections well. I'm sure you must have heard somewhere that current kills - not voltage; so don't be fooled by the low voltage of this circuit. I think a key word would be, 'respect.' Be aware when the thing is plugged in to the house power as you are working and please know that electrolytic capacitors (which you will surely use) hold power - lots of it - even when the thing is unplugged. Last thought . . . when you are done, put the power supply in a well vented, closed metal box with proper fuses. Good luck! | |
