Old 23rd February 2003, 12:35 AM   #1
Default Current limiter on a battery charger
Hi guys, I have a battery charger (manual multi stage) that I can dial up 16vdc on a 12 volt battery. Obviously the current runs from 15 ~ 25 amps depending on the state of charge. I wish to use the charger at 15 ~ 16 vdc but a max current of 4 amps for equalising purposes. What can I add to the circuit to limit the current. Thanks.
johndale is offline
Old 23rd February 2003, 06:39 AM   #2
you can use a curreny limiting circuit using current limiting transistor
hsvgtsr1 is offline
Old 29th July 2009, 06:31 PM   #3
hi guys i have 4.8v NI-MH battery.iwant to charge it how much voltage should i apply to its terminal to charge it completely through 10 ohm resistor
sabahat is offline
Old 29th July 2009, 07:13 PM   #4
You need to use constant current to charge ni-mh batteries, not constant voltage. What is the mAh capacity of the batteries? Take that value, divide it by 10 hours, and use about that much current for up to 14 hours when nearly completely drained to charge it fully.
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
Old 30th July 2009, 03:58 PM   #5
thank u for reply i am limiting the current at 200ma with a resistance 10ohm and i am using a 9v supply after one hour voltage on the terminal of the battery goes up to 6.2 volt and current drops to 100ma how much voltage can i lift or can igo on the terminal of bttery so the battery ll not damage the capacity of my battary is 2400ma-H.
waiting for ur reply
sabahat
sabahat is offline
Old 31st July 2009, 02:38 AM   #6
You can either stick what that resistor and charge for something like 24 hours or you can use a constant current supply such as an LM317. The datasheet describes how to use it as a current supply.
Noggin is offline
