| Can someone explain to me how to use a schmitt trigger to debounce a circuit. Also does anyone know the pin outs to the 4518B as i am making a decade counter using a seven segment display. | |
| I would not use a schmitt trigger for debounce, an R-C filter is easier. the pinout is below.
| Thanks very much for the help. Your right an r-c filter switch will be better. | |
| Russ, an RC filter is generally followed by a Schmitt trigger to give a fast risetime, as you undoubtedly know. What configuration do you have in mind? | |
| here is a short article on using schmitt triggers for switch debouncing: http://www.e-insite.net/ednmag/conte...ges/196470.pdf | |
| Thought I would my 2 cents worth. The reason that debouncing is necessary is that the mechanical contacts generally vibrate and cause more than just one closure or one brake of the circuit. The RC components and the one-shot MV eliminate the multiple mechanical bounces of the contacts, that most electronic circuits would normally respond to.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
