Old 25th January 2004, 02:25 PM   (permalink)
Default 3 and 6 volt supply
Can I center tap a 4 cell battery to get a 3 volt supply for one circut, and also still use the 6volts for another circut?
steveo
1Steveo is offline   Reply With Quote
Old 25th January 2004, 02:43 PM   (permalink)
yes
evandude is offline   Reply With Quote
Old 25th January 2004, 03:10 PM   (permalink)
Yes you can, but it's very bad practice!.
Old 25th January 2004, 03:40 PM   (permalink)
you can do this, if you have a battery that has 2/4 elements.
but this is not good because the first half, the one that powers the 3V will discharge faster. so it is not a good way.
you could use a voltage regulator and get 3V from the 6V. this way all the battery is discharged at the same time.
bogdanfirst is offline   Reply With Quote
Old 25th January 2004, 04:22 PM   (permalink)
What I trying to do is power a PIC micro an a motion dector off the same battery pack. Also use 1 of the microcontroler's output pin for a switch to VSS.
Im trying to get away from using a "optocupler" to keep the circut simple as possable.
What do you think?
Steve
Old 25th January 2004, 07:40 PM   (permalink)
Be careful, if you connect circuits together with different power supplies.
I most case they need the same grounding. So you must see it as a whole
circuit. Also the voltage to the input of an integrate circuit may higher than there power supply of the IC itself..
elec_lover is offline   Reply With Quote
