Old 22nd January 2004, 10:55 PM   (permalink)
Default powering relays
ok im using the parallel port to run my circuit. on this circuit there are 3 relays now relays 1 and 2 are both 2 channel relays, relay 3 is a single channel relay. the voltage when i set one of the bits high is around 2.7 i think. any ways it enough to power the single channel relay to switch it on. but for the 2 channel relays it requires 3.1v - 5v so im going to add an external supply of 5v. my problem is how to i get a high signal from the port to send the 5v to the relay to power it up and hence turn it on?
coma is offline
Old 22nd January 2004, 11:28 PM   (permalink)
Default Re: powering relays
How much current do they require? You could just send your high through an amplifier and boost the signal to 5V if all you require is a voltage level without much current to back it up.
-Gandledorf
Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems.
Gandledorf is offline
Old 22nd January 2004, 11:40 PM   (permalink)
well it very small what ever it is, i dont think current will be a problem. i was thinking of amping it up but i dont know how or how i could control it by sending a high signal from the parallel port?
coma is offline
Old 22nd January 2004, 11:55 PM   (permalink)
Either an op-amp wired as an amplifier, or using an amplifying transistor would work.
Shouldn't there be a 5V lead from the parallel port for powering external devices? I haven't worked with a parallel port in a long time, so maybe I am mistaken.
-Gandledorf
Old 23rd January 2004, 12:39 AM   (permalink)
even if there is a pin that supplies 5v i still need to control the relay with a 2.5v high signal
coma is offline
Old 23rd January 2004, 12:48 AM   (permalink)
You could use a ULN2803 transistor array IC to boost the output from the parallel port to drive relays, heres my circuit:
http://www.geocities.com/nettron1000/ParaPort3.html
Two roads diverged into a woods...i took the one less travelled by. R. Frost.
nettron1000 is offline
Old 23rd January 2004, 09:17 AM   (permalink)
No, there's no 5V output, one way to 'fudge' a low current 'almost' 5V output, is to AND any unused outputs together with diodes and set those outputs all permanently high.
Certainly for running relays off a parallel port, I would be using driver transistors (or a ULN chip) and an external PSU.
