Old 21st January 2004, 05:00 PM   #1
Default Wireless communication using IR
Have anybody around here ever experimented and have some details about doing serial wireless communication using IR leds?
Where can i find some info about it?
should i modulate my TX signal at the transmitter and demodulate it at the receiver?
And why should i use IR led and not UV or blue or any regular led?
It should be very interesting project...
udi_hakim is offline
Old 21st January 2004, 11:20 PM   #2
I never did this but I have a book that tells how. I think other colors would not carry very far, but you can hook them up to verify that you circiut is working.
try this link. it seems to have some helpful info
http://lnx.manoweb.com/lirc/?partTyp...rtName=placing
also try a google search:
http://www.google.com/search?hl=en&i...how+to&spell=1
Wish you luck!!!
goodpickles is offline
Old 22nd January 2004, 12:06 AM   #3
Default Re: Wireless communication using IR
There's various info about it in my tutorials at http://www.winpicprog.co.uk.
The obvious reason for using IR is that it's invisible - bit boring to use a torch to change channels on your TV!. Because of the huge amount of IR components out there, cheaply available, it makes good sense to use IR rather than visible light - far cheaper, and far easier.
BTW, IR remote control commonly uses a 38KHz (or so) carrier frequency, the data is then modulated on top of that.
Old 22nd January 2004, 01:42 AM   #4
It'll be interesting but is it going to be practical? You would have to line up the transmitter and reciever carefully for distances greater than shouting range and use powerful IR emitters and/or very sensitive IR light amplifiers. There must be no obstacle in the IR path either, its line of sight mostly.
If you look at what range ordinary IR remote TV controls work you'll see you could just as easily talk to the other person over that distance without any gadget.
Klaus is offline
Old 22nd January 2004, 05:15 AM   #5
If your going to use use the transmitter for distances longer than about 10 metres i would suggest using something like a radio transmitter. An infra-red led has a limit of something like 10 metres in normal conditions.
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
communication, wireless
