| Like you can tell from my subject, I don't know if this is either a good idea, or if I don't know what I'm talking about. Rain
__________________ When life gives you lemons... make a battery. | |
It's called 'perpetual motion', and is impossible. In your particular case (which has been suggested ever since electric motors were invented), there are a number of flaws - basically due to efficiency and losses. A motor puts out less mechanical power than it takes in electrical power, and a generator puts out less electrical power than the mechanical power it uses. For your scheme to work, it would require 100% efficiency from both motor and generator - which is impossible!. In order to actually take power from the scheme it would require efficiency higher than 100%. There have been many 'pertetual motion' machines designed over the years, all have the same basic need for greater than 100% efficiency. | ||
| your idea is simillar to the perpetual motion machine. start the thing and it will work forever. remember one thing that the total energy of a system remains constant. so u cant generate energy from nowhere. and power is the rate of expending energy. i hope u r understanding what i am saying (u would if u have studied physics). lets assume it works out for a short time. the motors are running. then u operate something from the motors. that something is the load of the motors. it will take energy from the motors and eventually the motors will be exhausted of all the energy they had. to continuously operate that load the motors need a continuous supply of energy which it doesnt have. and think of all the mechanical losses. friction :?: :?: i hope i went easy on u | |
| Rain
| Perpetual motion machines are theoretically impossible and would violate the second law of thermodynamics.But an interesting topic none the less, check out maxwells demon.
__________________ Eric. | |
| The question is good in that the discussion helps to convey an understanding of "what goes in must come out" and the numerous variations of that statement. Now and then we'll see where someone wants to do something - and hasn't thought that part thru. A popular one seems to be the budding audiophile who wants to design a 4 kw amplifier to run from his car cigarette lighter. The first thought on an experienced person's mind is "where's he goning to get the power..." No need to apologize. We all started at the beginning too.
__________________ stevez | |
| Hey Rain, these may be worth your reading time. The author has a sarcastic bent, but does an admirable job of explaining some basic physics. http://www.tinaja.com/glib/energfun.pdf http://www.tinaja.com/glib/hack64.pdf | |
| There is actually one design for a perpetual motion machine that works, and provides constant output energy for a fixed setup cost. It's rather complex, and I'm not sure of the symbols for the parts, so let me explain it and hopefully I will get across what I mean. Take some Triticum aestivum that has been heat set into a rectangular section, approximately 1/2" high, 4" long, and 3" wide. Coat one side with pasturized bovine colloidal gel. Strap this onto the dorsal side of a Felis domesticus, and drop from approximately waist height. The device will begin rotating as counter acting laws fight for dominance. It will make a lot of noise, and be pretty messy, but should rotate just above the ground indefinitely. Enjoy!
__________________ -------------------- -Gandledorf Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems. | |
| [groan] I can't believe somebody actually posted the old buttered-toast/housecat line here... | |
__________________ -------------------- -Gandledorf Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems. | ||
| | (permalink) | ||
| | (permalink) | |||
__________________ -------------------- -Gandledorf Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems. | ||||
| | (permalink) | ||
