Hi all, I refer to this circuit to build my ADC0808 in free-running mode. However, for the clock, I'm using the frequency generator at first for frequency about 500 kHz but it's not working. Then I tried use 555 timer in astable mode, and it still not working. Now I wonder the problem is with the circuit or with the clock. Any opinion? | |
Check the datasheet http://www.learn-c.com/adc0809.pdf pay attention to page 4 and first of all, check the outputs spec. Putting LEDs directly to ADC converter is definitely a problem (try bufferning outputs and for gods sake use some resistors in series with LEDs!!!). | |
I agree with Panic Mode. In addition, your schematic doesn't have pin 16 on it. It needs to be grounded.
Hi, Thank you for the advice. For the pin 16, it is grounded anyway in the schematic. The writing of number 15 and 16 looks similar. | |
| | #5 | |
I too had problem with same ckt. But solved. What i did is just adjusting the offset level of input voltage. Check the offset of input signal Try to connect your ckt with a signal generator and CRO, you can solve it very easily.
__________________ KP | ||
| | #6 |
Hello I have problem with adc0809. Values: Vcc = 4.9V Fclk = 100 KHz (Amplitude 5V) Vref+ = Vcc Vref- = 0V Vin = I have tested many values below Vref+ I don't know how to check if my adc is no damaged. Najeeb, could you tell me values adc is working correctly? If I connect SC (temporary) to ground I should reset my adc. There is no effect. If I apply Fclk (frequency) all diodes light! I check all connections they are good. I'd like to manually reset adc, if I turn on/turn off Vcc there appears nonstability (diodes don't correspond to Vin) or my adc is damaged. I need clear procedure how to test my adc. | |
| | #7 |
hello im facing the same problem same as u infact im using ur circiut diagram. can u tell me how u fix it?? thanks | |
| | #8 |
You cannot put leds directly to the ADC , you should make a pull down connection (put all the anodes of the leds in Vcc and when the adc outputs will turn low the leds will light up)
| | #9 |
Hello! can any one help me that how I can apply clock to ADC0808 and of what frequency waiting for reply BYE | |
| | #10 |
the output current of adc0809 is not enough to drive LEDs. Use some buffers at output..
| | #11 |
Hello all. This is my first post here, I require assistance with some analogue-to-digital circuitry. For my school project I am building a digital thermometer. An LM61 is connected to a ADC0808 whichs connects to an EEPROM which outputs BCD to 4511B's which drive 7-segment displays. While reading the datasheet for the ADC0808 I noticed that the output is Tri-State. Does this mean I need resistors branching off from the ADC's output to ground to prevent the EEPROM's address inputs from floating? Also, would a 555 be suitable for providing the 10-640kHz required for the clock input on the ADC0808? | |
| | #12 | |
The bipolar LM555 is OK up to about 100Khz or so. It won't work at 640Khz. I think the CMOS version of the 555 goes higher. I see no reason to clock the ADC really fast for a thermometer anyway as the temperature will change very slowly.
__________________ Inside every little problem, is a big problem trying to get out. Last edited by kchriste; 18th October 2008 at 05:03 AM. | ||
| | #13 |
Here I am reading posts from 2003. I was about to copy and paste parts of the datasheet then saw the very old date. Maybe very old threads should be tinted red.
| | #14 |
What's wrong with 2003 datasheets? This thread appears to have been resurrected several times over the years, I only used it because I can't start posts yet. I thought that the 555 could provide up to 500kHz? Or is it that it can't produce the right oscillations I require at frequencies higher than 100kHz? | |
| | #15 |
See KChriste's post. This version of the 555 looks like it will do what you want. http://cache.national.com/ds/LM/LMC555.pdf
__________________ Pay it forward. | |
| adc0808, problem |
