Old 5th December 2003, 01:39 PM   (permalink)
Default Air/Fuel Ratio guage Circuit
As the subject says I'm looking into building a circuit to display the air fuel ratio of a car, I was thinking of using 10-20 LEDs to indicate from lean to rich using various colored LED's. I found various plans online that use the LM3914 driver. I was wondering if anyone had any experience building this type of circuit (which in essence is just a voltmeter really) it will read voltage from the O2 sensor.
I was wondering if there was a way to only have on LED light up at a time instead of having them light up progressively. I'm not sure how to do this all the plans I've found light them all up as the voltage goes up.
Gotrek is offline   Reply With Quote
Old 5th December 2003, 02:31 PM   (permalink)
I've got answers First thing I'd like to point out is that you're probably looking for the LM3914, not the 9314...
http://www.national.com/ds/LM/LM3914.pdf
But the second answer is better. If you check out page 7 of that, they describe how to put it into bar or dot mode, including a mode using dot display with over 20 LEDs.
All of these are set using pin 9 (the "mode" pin). For normal dot, you just leave the "mode" pin open. For normal bargraph, you short the "mode" pin directly to pin 3 (V+). The huge graph is more complex, and you can read all about it if you want.
fat-tony is offline   Reply With Quote
Old 5th December 2003, 02:33 PM   (permalink)
You're correct about the chip I edited my other post thanks, and Thanks for the document thats exactly what I want
Old 6th December 2003, 02:24 AM   (permalink)
Default gauges
I put a gauge pcb together for a friend. You will achieve the best results using curved segmented LEDs.
\"There are only 10 types of people in the world: those who understand binary, and those who don\'t...\"
eemage21 is offline   Reply With Quote
Old 8th December 2003, 11:52 AM   (permalink)
Yes that probably what we were going to do, possibly also using a larger LED to indicate Stoich, lean, and rich
Old 9th December 2003, 11:51 AM   (permalink)
I found a simple diagram I'm going to follow But since I'm not an electronics guru could someone tell me what kind of part T1 and T2 represent? They are valued at 5k ohm but are they resistors? Thermistors? I don't know anyone have a clue? (I'm sure you all do)
[/img]
Old 9th December 2003, 03:22 PM   (permalink)
I'd suspect that T1 and T2 are just variable resistors. They set up the biasing for your reference voltage.
Old 9th December 2003, 03:27 PM   (permalink)
After looking up pictures of varible resisotrs I believe you are correct, thanks a bunch.
Like the silver boxes and the thing with the yellow screw type thing on tope right? Not the circled objects (nice tech talk ehh?)
Old 9th December 2003, 04:05 PM   (permalink)
I'm on Digikey ordering the stuff, can someon tell me What power dissipation value I want?
I need top adjusting, 5k ohm variable resistors but I'm not sure what wattage rating I need
Old 9th December 2003, 08:49 PM   (permalink)
That circuit will only monitor voltages of 1.25v or less. If you were to use that circuit as drawn, you should connect a 620 ohm resistor in series with T2, which is the LED brightness control. This will limit LED current to about 20ma each, which still may be too much current for the LM3914 if all LEDs are on and your LED supply voltage is more than about 8 or 9 volts.
What is the range of the voltage you are wanting to monitor? What is your supply voltage? How much current do you want to run through each LED? Answer these questions and we (I) can draw a complete schematic for you. I know that you said you wanted dot mode as opposed to bar mode. This will save power.
Roff is offline   Reply With Quote
Old 10th December 2003, 11:43 AM   (permalink)
I hope this helps
Basicly measuring from 0 ro 1 volt, input is 12volts
I plan on not connecting Pin 9 so only one LED should light at once
I stole the picture/circuit from http://www.ffp-motorsport.com/tuning/o2meter.php
Old 10th December 2003, 12:25 PM   (permalink)
Just so you know, that pic isn't even close to being correct.Outside of stoich there is no way of reading actual(or even ballpark) A/F from a normal oxygen sensor.They are effected too heavily from exhaust temperature.Over time they can help you get a "feel" of how your engine is operating, but don't think they are even close to correct A/F.I've seen more than one engine damaged from people thinking o2 voltage is some indication of A/F.
Eclipsed is offline   Reply With Quote
Old 10th December 2003, 12:32 PM   (permalink)
Ahh ok, the A, B, C on the graph represent the different curves based on different temperatures for the Lamda sensor, I guess that explains it
Old 7th January 2004, 04:25 PM   (permalink)
Sorry to bump up this old post but in the picture of T1 and T2 what are the pin assignements? I'm not sure how to wire it up.
Old 8th January 2004, 08:37 PM   (permalink)
a a/f gauge off of a stock 02 sensor is pretty much worthless..
it won't really give you any USEFUL information other than the 02 sensor is actually working.
njcfm is offline   Reply With Quote
