Old 1st December 2003, 03:53 PM   #1
Default The use of a Monitor!
How can I use a PC Monitor to display graphics?
For example to display the character 'A' with red color!!!
matasoft is offline
Old 1st December 2003, 05:51 PM   #2
What are you using to drive the monitor?
ChrisP is offline
Old 1st December 2003, 06:21 PM   #3
I dont think you can cause the monitor relies on digital to analog conversion output from a video card which would be pretty complex to rig up with out a computer or lots of microcontrollers and ic's.
I know pin one on a monitor connector is Red Out But i dont know what you need to drive it
windozeuser is offline
Old 1st December 2003, 08:00 PM   #4
Pc monitor signal consists of 5 signals
RED - GREEN - BLUE and VSYNC - HSYNC
V and H sync contain fast pulse trains that indicate vertical and horizontal syncronization signals. The monitor uses these to switch internally to the desired resolution and, obviously, for synchronisation.
Pretty complicated to just create such a signal out of thin air
Exo is offline
Old 2nd December 2003, 06:01 PM   #5
I know that I have to generate signals for the VSYNC and HSYNC pins but I don't know the sequence to light a pixel. When I know that then I will use a microcontroller as a display driver.
matasoft is offline
Old 2nd December 2003, 06:26 PM   #6
A monitor is simply an analogue display screen, it doesn't have 'pixels', to light a particular point on the screen you need to generate the correct sync and video signals (three video signals, one for each colour) to make the signal high at that exact moment in time.
Old 2nd December 2003, 07:18 PM   #7
When I read your post I remember I saw once a place that had a tetris game with a monitor using a PIC16F84 :lol:
So here is the link: http://www.web-ee.com/Schematics/PIC.../PICTetris.htm
If you search in google for tetris and PIC16F84 a whole bunch of stuff comes up that might be useful. Good luck
Ivancho
ivancho is offline
Old 2nd December 2003, 09:38 PM   #8
It's well worth a look at (although I've never managed to get Tetris to work, but Tennis worked OK) - but bear in mind it's for a standard 625 line, 50 Hz field TV/monitor. A PC monitor is nothing like this, and most multi-sync monitors won't go anywhere near low enough.
Old 3rd December 2003, 03:25 PM   #9
this is rickard's site, has pong and tetris for TV... still he has to go to the limit to, get this working on a pic and a pc monitor runs even much faster then a tv... I don't know it is possible
Another way would be to make your controller put it's image results into external RAM and then use a general VGA ramdac to convert it into VGA... takes a load of the pic
http://www.rickard.gunee.com/projects/
Exo is offline
monitor
