Old 30th November 2003, 08:24 PM   #1
Default determine battery level
how to determine the battery level when it is low?can we measure the capacity of the battery or we determine from its voltage level?i need it for my robot coz when the power is low, it will alert me.
thank u
electricano is offline
Old 30th November 2003, 09:16 PM   #2
Default Re: determine battery level
thank u
You need to know exactly what type of battery you have, and it's discharge curve, there are some discharge curves here http://www.lpilsley.co.uk/viewbatt.htm which I plotted years ago. It's up to you to decide at what point you need to initiate a low battery warning - as you can see from the Alkaline and NICAD (particularly the NICAD) they maintain a reasonably constant voltage and then suddenly drop. I haven't tested lead acid batteries (they don't make AA ones!), but I suspect they may well behave in a similar way to NICAD's.
Old 30th November 2003, 09:56 PM   #3
I'd just go with a voltage measurement.
\"There are only 10 types of people in the world: those who understand binary, and those who don\'t...\"
eemage21 is offline
Old 3rd December 2003, 08:03 PM   #4
how to implement voltage comparison to determine the battery level.if can, plz provide me links or circuit diagram.thank you
Old 6th December 2003, 09:48 PM   #5
can anybody helps me with this one?????
Old 7th December 2003, 03:02 AM   #6
Similar thread here:
http://www.electro-tech-online.com/viewtopic.php?t=2884
Two roads diverged into a woods...i took the one less travelled by. R. Frost.
nettron1000 is offline
Old 7th December 2003, 03:54 AM   #7
Adjust R2 for whatever voltage you want to LED to light up at when it gets below that set point.
dingo is offline
Old 7th December 2003, 04:17 AM   #8
Here is another circuit that is very simple.
You get about .6 of a volt drop over a doide, a transistor needs at least .6 of a volt to switch. The buzzer in the diagram below will sound if the voltage gets below 2.4 volts (that is if you can find a buzzer that works off less than 2.4 volts).
To make this work at 12 volts you will need around 19 doides and to adjust you just add or remove doides to give you .6 volt steps.
all resistors are 10k, transistor BC547 or any general NPN one, doides you can use any, a signal doide is ok.
dingo is offline
Old 7th December 2003, 02:12 PM   #9
hahah funny 'high power' batteries. Thanks for the link, I considered something like that for a high school science project but decided to give beer to newborn mice instead (no kiddin)
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
Old 15th December 2003, 09:33 PM   #10
thank u
Hi
why don't you use a comparator. You can easily build it with simple opamp circuit. Please see LM301 data sheet. (National Linear series). You may find lots of application in the data sheet.
Regards,
Levent Anadol
lanadol is offline
Old 16th December 2003, 05:39 AM   #11
Not saying that these comparator circuit will not work for voltage comparisons, I think that Nigel is absolutely right. A battery voltage-capacity curve depends on the type of battery, the ambient temperature, the discharge type (heavy or light), and the age of the battery. Since you did not mention the type of battery you are using, you could be up to 50% off on some types of battery chemistries.
Jem
jem is offline
battery, determine, level
