Old 26th November 2003, 07:35 PM   (permalink)
Default seven segment led display homemade
Would it be possible to make a seven segment led display using individual leds behind a faceplate with slits cut in it..... I know I can make the faceplate and the isolate the light from each individual led I just dont know how much power the individual leds would use compared to a normal seven segment led display.
sebut44111 is offline
Old 26th November 2003, 09:04 PM   (permalink)
Why Not Just Use A 7 Segment Led And Save Some Trouble i think Individial l.e.d's would actually take more current to power them then a 7 segment l.e.d Display Cause the l.e.d's used in the display's are much smaller and thus use less power correct me if im wrong
windozeuser is offline
Old 27th November 2003, 12:14 AM   (permalink)
There is no reason your home-made 7-segment display would use more power than a commercial unit, unless you are making it larger, and I can't think of a reason to make your own otherwise.
Russlk is offline
Old 27th November 2003, 02:44 AM   (permalink)
Yes it is possible to make your own 7 segment display using LED's.I did it once and I used flat top LED's. You can make either common anode or common cathode types.Only thing to keep in mind is that the operating current of a LEDs must be limited to a safe value via a series resistor connected to either the C or A. So go ahead.
Cheers !
\"Waste your money and you\'re only out of money,but waste your time and you\'re lost part of your life\"
Ravi is offline
Old 27th November 2003, 03:18 AM   (permalink)
Seems like a lot of work to me and money making a Led Display When U Can Buy One For Like $2 But Unless Ur Real Disprete or bored... :P
