Old 23rd November 2003, 06:24 PM   (permalink)
Default Help - need to a circuit to trigger relay
Hi
can someone help me. I need a circuit that will trigger an output to a relay when it get a predefined input voltage
input voltage - 3.19 volt, will be using ground to measure this input voltage
Any help would be greatly appriciated
Ray
5neaker is offline
Old 23rd November 2003, 07:15 PM   (permalink)
Sounds like a good application for a comparator circuit. Heres a link to some info and schematics.
http://home.cogeco.ca/~rpaisley4/Comparators.html
Two roads diverged into a woods...i took the one less travelled by. R. Frost.
nettron1000 is offline
Old 23rd November 2003, 10:24 PM   (permalink)
Note the diode across the relay solonoid coil, that is needed to protect the IC output from the inductive kick when the relay is turned off.
Russlk is offline
Old 24th November 2003, 11:43 AM   (permalink)
You could just implements a diode limiter circuit... I can\t draw you a schematics right now, but as soon as I get my hand on my PC, I'll post it. By the way, how does your input looks like? Is it a 3.19V DC?
Agent 009 is offline
Old 26th November 2003, 05:18 PM   (permalink)
Do a google search for datasheet on ULN2803. The ULN28xx family is an octal darlington pair driver well suited for driectly driving relay coils over a broad voltage range and fairly hefty power outputs from a DIP package. No need to build from discrete components when a perfectly good IC package exists than can do 8 for the price of 1.
Dialtone
Dialtone is offline
Old 27th November 2003, 07:06 AM   (permalink)
I would go and use something like a zener diode in series with a voltage dropping resistor to trigger a transistor, which then triggers the relay
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
