Hi, Can any body give me some info regarding different IR sensors available today or atleast provide a link? Along with that i would also love to know all about the IR receiver of a TV remote control. Thanks, Surya | |
The IR modules used in TV remote controls incorporate the phototransistor, gain amplifier, and demodulator in a single package. They usually output an inverted bit stream. Sharp GP1U52X Vishay TSOP1140 (I prefer this one) | |
Thank u crust, But u wrote,"They usually output an inverted bit stream". What does that mean. Maybe i got it wrong. Can u please xplain me? Thanks.. Surya | |
Inverted bit stream means when the sensor detects IR carrier or signal, its output goes from logic-high to logic-low. i.e Active Low Output. So if you send 1100 through IR LED, the receivers output will be 0011.
__________________ "There is no way to peace, peace is the way!" | |
| | #5 | |
There are some details on IR communication in my PIC tutorials at http://www.winpicprog.co.uk/pic_tutorial.htm - they are based on the Sony SIRC remote system. | ||
| | #6 | |
__________________ "There is no way to peace, peace is the way!" | ||
| | #7 | |
Obviously the values you quoted are pretty high, and it's quite possible most uses would require an external resistor. If I get time tonight I'll disconnect the pull-up resistor on one of my IR Boards and see what voltage I get on the output pin (without any connection to any kind of load of course). | ||
| | #8 |
I concur with kinjalp that in fact they are *not* open collector outputs. You can definately use them without an external pull-up. Having said that, I always use external pull-ups because the high-z internal pull-ups dont seem to provide as much noise immunity as a 1k or so external pull-up. In this datasheet a 30k pull-up is shown in their internal schematic. | |
| | #9 | |
Regardless, I'm not planning ever using one without a pull-up resistor, it appears to be normal practice commercially (where they save every resistor they can) - so I'd sooner stick to proven reliable practice. But thanks very much for the info!. | ||
| | #10 |
Thank u guys, Can the IR component of sunlight affect such an IR receiver (the one used in TVs,VCRs etc.)? I am using a similar sensor(GP1U26R series from SHARP) for my project where it is used to receive the reflected IR signals from an obstacle. The transmitter is an IR LED operating at 1kHz. The entire unit is used for proximity detection. :?: Hence, do i need to have any kind of covering of the unit from direct sunlight? :? Well, i do have some understanding regarding infrared rays, but is there any link through which my knowledge regarding IR is complete so that i don't have any further misconceptions in the future? Thanks again, Surya | |
| | #11 |
The receivers in TV uses modulated infrared signal and so it has very high immunity to sunlight or any other ambient IR source. The modulation frequency for most receivers is 38kHz, however it may vary with type of receivers. Check out your receivers specs. The LED should transmit signal at same frequency which a receiver can detect. I think 1kHz is too low and I have never seen any receiver with this carrier frequency.
| | #12 | |
