I checked the datasheet, and I believe
Jameco p/n 148582 is spec'ed to work with your load, so long as it is resistive. I believe you can drive an inductive load as long as you connect a
BIG snubber (flyback) diode, reverse biased, across the load. The coil current will be about 150ma@12 volts. You should also have a snubber diode such as 1N4001, reverse biased, across the coil. You can power the coil with up to about 15 volts without damage.
What is your load?
BTW, it would behoove you to check your spelling when you mention a vendor's name. If I hadn't known of Jameco (which you spelled Jamaco), I would not have been able to help. If you really intended to say Jamaco - never mind!
