I have an old motor-blower assembly from a furnace that i am thinking of using for an air filtration system. I would like to hook it to a on/off switch, then to a plug so i can plug it into a receptable. motor ===== on/off switch ===== plug ->receptable From the motor assembly, i see only a two uncolored wires. How do i wire this so that i willbe safe? Can i just wire it without ground to the switch thten to the two prong plug? Thanks in advance, | |
| | #2 | |
Use a 3-core cord and 3-prong plug (with the earth connected all the way through, of course), and terminate the earth wire somewhere on the motor's chassis (you'll probably need a lug on the end of the earth wire). The switch must operate in the ACTIVE (hot) lead, not the neutral - unless the switch is a double pole switch, with switches both active AND neutral. | ||
Don't you think that polarity would affect the motor's direction of rotation?
| | #4 | |
In order to reverse the direction of a single phase motor, it is necessary to reverse EITHER the starting winding, OR the running winding, but not both. | ||
Yes, indeed, AC motors aren't affected, or if they were, the vaccum cleaner would start throwing out the dirt, if just you switched the orientation of the plug... But for DC motors, I didn't know that they could not be affected by the input's sign...
| | #6 | |
| | #7 |
Regarding the switch - make sure the contacts are rated for the application. Usually in the US the switch will have a current rating in amperes as well as a HP (horsepower) rating to address the inductive properties of a motor load. A switch that doesn't have a HP rating probalby shouldn't be used.
__________________ stevez | |
| | #8 |
Thanks guys!! This is the first time i posted here...can't believe the quick reponses. Much appreciated guys!! I just have one followup question. Since i will be using this in a air filtration system, how must is dust a concern since the the motor is not an enclosed one. Would it be sufficient just to put the motor=blower in an enclosed area, with a filter on the intake?? | |
| | #9 |
I have done air cleaners in the past. The (blower) motors I used had 3 speeds (high,med.,low). I enclosed them in a box that had 2 openings. Where the air went in I put a electrostatic furnace filter on and where the air came out I put a grill on. It seemed to work great until one day I notice a lot of dust coming out. I picked up a handful of saw dust and drop it by the filter. That's when I noticed that it would catch the larger particles put not the fine dust (the ones that plug your lungs). So unless you can find a really super good filter, it won't work well. I find furnace (blower) motors are great fans. The bigger ones can blow air up to 40-50 feet. Great to have around when you're working outside on a hot summer day.
