Old 13th November 2003, 07:55 AM   #1
Default how does schmitt trigger work?
hi guys,
anyone have a link to where i can find information regarding schmitt triggers? And also, anyone know how a square wave oscillator operates? Thx
Plue is offline
Old 13th November 2003, 12:54 PM   #2
Default link for Schmitt Trigger.
http://www.play-hookey.com/digital/e...l_schmitt.html
If you have a little knowledge about Schmitt Trigger This will help youu.
For a better knowledge on Schmitt Trigger, First learn Comparators and Zero Crossing Detectors
The file that I have attached will give u little more knowledge on Schmitt Trigger
cruel_intentions1984 is offline
Old 14th November 2003, 11:54 AM   #3
Default Re: how does schmitt trigger work?
There are many different types of square wave oscillators out there. Which one in particular, are you interested in?
Phasor is offline
Old 14th November 2003, 12:46 PM   #4
Did you meant the shcmitt trigger implemented by an operational amplifier? Because if you did, I can send you a whole experiment I did in the campus's lab, about schmitt triggers...
Agent 009 is offline
Old 15th November 2003, 01:22 AM   #5
If you think about TTL or CMOS schmidt gates in simple RC oscillators
it is quite simple. On power up capacitor is empty ("0") so output of the inverter is high. Capacitor charges through resistor till input reaches level for logical "1". In that instant, output is inverted to logical "0" so
capacitor discharges through same resistor. Once the capacitor is low enough, input is considerd "0" what forces output again to be "1" and whole cycle repeates.
If you add potentiometer in series with resistor, you can change frequency. If you replace resistor for two resistors in parallel and add diodes in series with resistors (oposite polarity for diodes), you can change independantly time to charge and discharge capacitor. This way
you can easily change duty cycle.
panic mode is offline
Old 15th November 2003, 01:31 AM   #6
Here is the osc. with adjustable duty cycle
Old 15th November 2003, 05:36 AM   #7
Here is a another link:
www.discovercircuits/s/schmitt.htm
\"Waste your money and you\'re only out of money,but waste your time and you\'re lost part of your life\"
Ravi is offline
Old 18th November 2003, 03:19 AM   #8
Default schmitt trigger
hi plue,
well here are more bits of info i can share with you;
a schmitt trigger is basically a bistable device with a very fast response and has hysteresis or dead band. its output changes at a specified value of the input lelvel and resets at a different value. now the difference between this values is what you call the "dead" band. so any changes in the voltage level within this band will not trigger this schmitt device. there are ics designed to react in this manner and you can also design this with the use of discrete devices as what "cruel" has referred you to.
as you see, in actual scenarios digital signals are really not that clean as what we expect, there are noisy signals as well as slow rising signals that sometimes it would not have enough strenght to trigger a digital device.
as far as i know for debouncing or signal conditioning this device offers a very good response.
further more, in reality many devices are edge triggered rather than level triggered, meaning the signal should have a very fast rise time so it can be recognized. likewise a slow rising signal with no sharp edge cant trigger a digital device. so the practical solution is to convert the sine wave to square wave by employing the schmitt trigger.
hope this could further your knowledge about schmitt trigger.
\"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
mozikluv is offline
