Hi, I am new to electrontics but have read some tutorials and have one question about a transistor the one I am looking at is jam #2n3903. Here is what I want to do. I want to put a cap before the base of the trasistor because the input will be pulseing this way it will be a constant flow of electric before it goes into the base. I know the base need 6 volts but the teck sheet does not tell me any thing else about the base requirements of the transistor so that I can figure out what size cap I need or can I find the size of a cap I need with just the voltage?
2N3903 is general purpose NPN transistor. Like any Si-type NPN transistor, base voltage is ca. 0.6-0.7Volt (not 6V). Post your circuit and explain what are you trying to do if you need more help. | |
thanks for your reply. when D=on it will be pulseating on off on off on off ect (like a turn signal) and so I put a cap after D so that while d=on it has consent power going into the base of the transitor that way I will get constant power out of the emitter ( and not on off on off on off). But when D=off there will be no power threw D so the cap will need to decharge with in 1-2 seconds so that the emitter will not emit power . Now what i am trying to find out is what size cap to put in. So in order to do that i need to find out how much current the base uses (If any ). Do you understand what I am trying to say. I don't have to use the ezact model transistor, but I have to use a transistor! If there are any more questions please ask thanks
How much amps does the base of the transistor use the model is jam # 2n3903 thanks | |
| | #5 | |
Values of hfe ranging from 40-400 are common for small signal types. | ||
