Old 14th October 2008, 08:57 AM   #1
Default clock phase and noise
if i have a digital signal that i want to recognize, i sample in the middle of the bit to know its a zero or one.
sampling in the middle can be done using a local clock that is 5 times faster than input rate, which results in each bit contains 5 local clocks and u can sample at the third local clock.
if there is sm amount of noise in my signal, it may result in 4.9 local clocks per bit which means an error in sampling after a certain amount of bits..
I want to draw a graph of my bit error rate vs noise/power for such a system. how?
if i have 4.9 clocks instead of 5, thats 2% noise. how much shall i consider No in this case?
thank you.
subzero... wins..
sonaiko is offline
Old 14th October 2008, 01:25 PM   #2
Huh? What are you getting at? Why are you oversampling a digital bit? Is it Manchester encoded?
Bill
Smart Kits build Smart People
Old 15th October 2008, 06:17 AM   #3
no its NRZ.
Im oversampling becoz there is some kind of jitter on my received signal..
Since I am only simulating and I am generating my own digital signal with noise, I want to draw a graph of BER vs No/Eb. Where Eb is energy per bit. But I am not sure how to calculate No in this case..
subzero... wins..
sonaiko is offline
Old 15th October 2008, 06:31 AM   #4
Wouldn't that be Eb/No ? So your case is you either oversample by 1 bit or undersample by 1, I don't remember the math but I think it is about 7.5 dB of noise which might be significant.
Not sure if I worded the over/under sample thing right. What I mean is Noise might cause 1 of 5 to miss or hit a sample.
Pay it forward.
Mikebits is offline
Old 15th October 2008, 08:08 AM   #5
Yeah exactly.
If every 25 bits I am oversampling by 1, then how would I graph this information into BER vs No/Eb?
subzero... wins..
sonaiko is offline
Old 15th October 2008, 02:01 PM   #6
Actually the question is:
Since I care about the baseband section of the receiver, i.e after demodulation and down conversion of the received signal,
Do I really need to care about the BER vs Eb/No?
I think the BER graph depends on the modulation and doesnt change when changing the decision techniques used in baseband, does it?
subzero... wins..
sonaiko is offline
Old 15th October 2008, 09:58 PM   #7
Well, if there is probability for error, then error would cause bit error even in baseband. To be honest, this is not my area, but I can recommend a good resource.
Digital Telephony by John Bellamy. Section 4 contains all the juicy math and such for BER. My edition is 2, but there is a ed 3.
The book shows BER Eb/No graphs.
Pay it forward.
Mikebits is offline
clock, noise, phase
Phase shift - Phase Angle windozeuser General Electronics Chat 20 20th March 2009 10:39 AM
Phase Sequence or Phase Present neelam29 General Electronics Chat 7 23rd May 2007 11:25 AM
Modulation phase noise Someone124 Electronic Projects Design/Ideas/Reviews 0 24th September 2006 12:59 PM
Three Phase Versus Single Phase For EV fzn10 General Electronics Chat 4 31st July 2006 09:39 AM
converting 3 phase motor to single phase norberto fines Electronic Projects Design/Ideas/Reviews 6 2nd September 2003 11:21 PM
