purchasing new power supply
  1. #1
    2Electrified 2Electrified is offline
    I am looking into purchasing a power supply. I came across two that I am interested in. The only difference is the amps - one is 3Amp and the other is 5amp. The cost difference is about $60.00. Being a 2 amp difference is there a significant difference. Here are the two I am looking into.
    HY3003D-3 30V 3A Dual Output, 4 Digital Displays Variable Regulated DC Power Supply Extra independent 5 V/3A output
    HY3005D-3 Dual Output, 30V 5A, 4 LCD Digital Display Variable Regulated DC Power Supply, extra independent 5V/3A output
    I am not sure which one to purchase, like I mentioned, basically the one difference is one is 3A and the other is 5A. Does the 2A difference really make a significant different for using on testing your basic circuit boards.
    Any input would be greatly appreicated, or you suggest another brand/type I would welcome any input.
    Thank you in advance your response.
    Lisa
  2. #2
    Willbe Willbe is offline
    Quote Originally Posted by 2Electrified View Post
    . . .not sure which one to purchase
    For each supply, plot the current on the Y-axis and the price on the X-axis. The third data point is zero amps for zero dollars.
    If you collect data (from catalogs or the Internet) for several supplies around 3A to 5A you may see a flattening of the curve. This area probably shows where the manufacturers are competing for the best $/amp ratio, other things being equal.
    Then you can see how your two supplies are doing in the whole scheme of things. Outliers
    http://www.google.com/search?hl=en&q...ine%3A+outlier
    should be disregarded or researched.
    Hopefully a bargain will jump out at you.
    Then the question of quality becomes important. I doubt that any manufacturer is going to tell you the real value of his calculated MTBF.
    http://www.google.com/search?hl=en&q...BF&btnG=Search
    I used this method on another forum to rate two cordless electric drills for watts/$, A-h/$ and torque/$. Some parameters came within pennies (~1%) of each other and I do not believe this was a coincidence.
    Then another poster came up with a drill that beat the pants off of the first two using the same system and was also rated a Consumer's "Best Buy".
    0
  3. #3
    crutschow crutschow is offline
    For most electronic testing 3A should be adequate. Typical circuit boards generally take no more than a few watts. You would likely only need more current if you were testing something involving motors, such as stepper or servo devices, or high power amplifiers.
    0
    Zapper
    Curmudgeon Elektroniker
    --Inside every little problem is a big problem trying to get out.--
  4. #4
    rezer rezer is offline
    The 3A should serve you well for general electronics projects.
    0
  5. #5
    RadioRon RadioRon is offline
    I agree, 3 amps is enough. I do many of my projects with either a 1A or 2A supply and find that these cover about 80% of the work. Another 18% of the time I need to work on something for a car, like for example a two-way radio, and in these cases I use a 13.6V 20A supply or a GelCell (12V battery) just for that purpose. The remaining 2% need something that these won't supply.
    0
    RadioRon
  6. #6
    tj107us tj107us is offline
    I have the HY5003 which is a 3 amp 60v power supply, and it works great!!!
    0
  7. #7
    Get adjustable current limit; it's great for tracking down shorts without smoking stuff or using up fuses.
    For more flexibility, you can also build your own modular supplies with a diode bridge/heatsink, a Variac, rheostats, etc., with dirt cheap parts from Hosfelt.com or Allelectronics.
    0
Power Supply Experts!! Need help with KEPCO Labs Power Supply headbuttking2 General Electronics Chat 4 8th December 2010, 07:09 PM
Purchasing parts and log pot questions bacterozoid General Electronics Chat 5 8th May 2008, 12:59 PM
Purchasing SRF04 in Canada micro571 General Electronics Chat 2 3rd April 2006, 05:49 AM
Which site is recommended for purchasing electronic parts? ajamesr2 General Electronics Chat 3 23rd August 2005, 11:47 PM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002, 01:10 AM
Page Time: 0.06128 seconds      Memory: 7,531 KB      Queries: 16      Templates: 0
