| I'm interfacing a PIC with a bunch of 3.3V devices. I *might* need to run the PIC off 5V for reasons I'll mention later. If the PIC is running off 5V, can I just use pull up resistors on the SDA and SCL lines to the 3.3V supply since they are open drain/open collector? The reason I might need to use 5V is because of ICSP programming and USB stuff. I have to check if the 18F2550 can handle flash mem erases with a 3.3V supply with my programmer (melabs U2) and whether or not I need a 5V supply for any of the USB stuff. | |
| I think you will have problems as the inputs to the I²C module are schmitt triggers and require 0.8*Vdd for a valid high. This is only my interpretation of the data sheet and so I could be wrong. There are various ways to solve this problem. See Microchips Hints & Tips Mike. Last edited by Pommie; 29th September 2008 at 12:52 AM. Reason: Changed link. | |
| Nuts. I was thinking they would just be TTL/CMOS compatible. | |
| I just found this, which looks like an awesome and cheap solution to the problem. It just takes two MOSFETS and two additional pull-up resistors, is bidirectional, and offers isolation between the 3.3 and 5V sections when either power supply is powered down. http://www.standardics.nxp.com/suppo...df/an97055.pdf Last edited by speakerguy79; 29th September 2008 at 02:32 AM. | |
| Simple question | speakerguy79 | Electronic Projects Design/Ideas/Reviews | 8 | 14th July 2008 07:17 AM |
| simple question ? | amenoera | Electronic Projects Design/Ideas/Reviews | 3 | 21st June 2006 03:38 PM |
| Simple PIC question | George L. | General Electronics Chat | 16 | 17th April 2006 10:25 PM |
| Very simple question 2 | zambalik | General Electronics Chat | 3 | 17th July 2004 12:29 PM |
| very simple question | xjackal | General Electronics Chat | 10 | 25th November 2003 07:50 PM |
