| Hello, hoped you all could help I am trying to create a circuit that will take an input from a PWM circuit (only needs to be 50% duty cycle) such as 555 or any other integrated PWM, and be able to create 2 or more signals phase shifted from one another. so for example, say I want a 50 hz signal in, and two 50hz signals out with an adjustable phase shift. Then maybe I can go on to a fet driver to up the signal. Any ideas? lemme know if you want me to be more specific. thanks! | |
| oh I forgot, I would like the two signals to come out of two different pins, so that I can control separate fets | |
| Hi, Can you live with 100Hz input and two 50Hz outputs? | |
| sure, input can go anywhere up to 1.4mhz, I just want to be able to control the output freq and phase in order to drive 2 or more mosfets, | |
| Do you want 50% on the phase shifted outputs, or variable duty cycle, or...? What frequency and phase shift ranges do you want? | |
| Why do you think you need phase shift?
__________________ Forget injuries, never forget kindnesses. | |
| Hi again, If you can stand 100Hz on input and 50Hz for both outputs and you want to vary the phase of one output you can run the 100Hz into a flip flop, the output Q will give you the first 50Hz output at 0 degrees, and run the 100Hz into a one shot for a delay, then run the one shot output into another flip flop, the output Q would be phase variable from 0 to almost 180 degrees, and the output Q' would be phase variable from 180 to almost 360 degrees. Both outputs would have a 50 percent duty cycle. You may have to set up the one shot to have different cap values however for higher and lower bands of frequencies. Last edited by MrAl; 24th September 2008 at 03:00 AM. | |
| One shots have one big inherent problem. That is the analog portion and stability. It would be futile to expect predictable results from a one shot. Stabilty and reproducibility would never make a one shot a viable idea. Again I question the need for phase shift.
I guess that's why they dont make one shots anymore? he he. I used a one shot for many circuits, including one that is very very similar to this one that had to control the phase angle of another circuit trigger, and it had to be adjustable. I also know people use 555's for controlling servos, but i've never done this myself. In fact, i think 555's are used for one shots quite a bit. What i dont know is if the OP uses uC's or not yet. That would be my first choice. Last edited by MrAl; 24th September 2008 at 04:14 AM. | ||
| Thanks for the repplies As to why I need the phase shift, it is because I am experimenting with rotating magnetic fields and would like manual control of the phase angle. The one shot is a brilliant idea, but I had not heard of its inherent instability, which would be a big problem as the circuitry would be driving resonant loads. I know there is such a thing as a shift register IC but have not used them. Perhaps someone with a bit of experience in this field would be able to point to a good IC and perhaps a schematic. | |
| Hi, The so called "instability" is relative to the application. In other words, any jitter would be a small percentage of the total period and this would only affect the application slightly. Whether or not that jitter would ruin the application is something that would have to be assessed of course, but one example where the jitter is small relative to the time period is with the control of a triac trigger, where the one shot produces a delay after the zero crossing so the gate can be fired at some time later, which regulates the output power. This works out extremely well for regulating the power to an ac operated device like a motor or lamp. The motor runs very smooth and the speed goes from full down to almost zero. The frequency is rather low however, around 60Hz, so the jitter affects it probably less than 0.1 percent. At higher frequencies it might affect the phase shift more so you'd have to try it. Other ways of adjusting phase are possible, for example using a phase shift network and then detect the zero crossing, but this isnt as easy to get the full 0 to 360 degree (or nearly that) phase shift, and after all nothing is going to be perfect. A PLL is another idea. Generating a ramp and detecting a particular voltage level is another way to do this. Depending on the frequency and what kind of phase step increment you need, you might also use divider chips or of course a microcontroller. It might be a good idea if you tell us the min and max frequency you will be working with. The lower the better actually. Also, what the min step in phase you need, such as 1 degree. The bigger steps are easier to generate. Last edited by MrAl; 29th September 2008 at 03:48 AM. | |
| He never answered my questions. It's hard to help someone who won't answer questions. | |
| mosfet, phase shift, pwm |
| while(feet!=wet) { search(friendly="Linux", hardware="avr", software="kde desktop");} | FirefighterBlu3 | Micro Controllers | 6 | 12th September 2008 06:31 PM |
| Obtaining a "good" square wave for high frequency | ijuset | Electronic Projects Design/Ideas/Reviews | 8 | 29th August 2008 03:06 PM |
| Changing "dark on" switch to "light on" | NewUser | General Electronics Chat | 3 | 15th September 2007 04:30 AM |
| "Heavy Duty" Square Wave Oscillator | Hayato | Electronic Projects Design/Ideas/Reviews | 24 | 25th June 2006 11:32 PM |
| Three phase "systems" | hydro | General Electronics Chat | 11 | 25th November 2003 09:21 AM |
