| If you connect the two terminal of a battery with a very low resistance that makes a short circuit, what is ..? the lowest resistance that would not make a short circuit? | |
| | (permalink) | ||
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |||
| Technically a short circuit just means a connection across any two points where the resistance is low enough to "too much" current to flow. "Too much" depends on the circuit itself. For a computer circuit 10mA may be too much. For a small motor, 50A might be too much. For a power grid it might be hundreds of amps. It's more of a qualitative term than a quantitative term. For example, if you got a large 12V Lithium Polymer battery and connected a 12 ohm resistance across it so there was 1A of current flow and the battery could provide that current without overheating and the resistor is large enough to dissipate the heat, it's not a short circuit. But if the battery was too small to provide that current without overheating or the resistor was too small so that it got too hot, it might be considered a short-circuit. THe closest definition I can come up with for a short-circuit resistance is a resistance that is "for all intents and purposes" is zero, negligible, or very small for the circuit in question.
__________________ NO, that picture isn't me so don't bother asking if we can be friends. Last edited by dknguyen; 23rd September 2008 at 03:36 AM. | |
| A short circuit is simply a low resistance path close to 0 ohms. If you have a 3 ohm resistor hooked up to a battery and the load causes the battery to become overloaded, what you have is an overloaded battery, not a short based on the definition of what a short is. For instance, if my 5V regulator is overloaded causing the output voltage to drop to 0.5V, I don't have a short but an overloaded condition. If I then measure 10 ohms of resistance on the 5V bus, it's not shorted, just overloaded. Remember a short will be close to 0 ohms such as your wire.
__________________ "Remember, you're special.....just like everyone else." | |
| It seems that there is more then one valid definition.
| From my understanding, a short is an extremely low resistance across a power sourse - not intended. It makes electronics PUFF and SMELL
__________________ Proper Planning Prevents Piss Poor Performance Last edited by Boncuk; 23rd September 2008 at 05:05 AM. | |
| what about: a short circuit is if the resistance form pole to pole of the power source is lower than the source its internal resistance. Robert-Jan | |
| That sounds arbitrary. I like the Wikipedia definition that 3v0 posted. | |
| It is the lowest resistance possible, in a circuit were the battery, resistor or the fuse don't blow! (don't take this literally, the battery might not "blow") | |
| I have seen shorts on PC boards that were not "the lowest resistance possible". | |
| All the answers are in Thevenin's theory. | |
| if you are considering a path for a battery(not components) a short can also be regarded as the resistance(ideally 0) which drains the battery in the least amount of time. although conventional definitions have been given above.
__________________ i would explain it to you but it would make your brain explode! | |
| As far as I'm concerned, there is only one definition of the term short circuit. It simply means an undesired electrical connection that compromises safety and/or causes the device/system to malfuction.
| short circuit protection | raed | Electronic Projects Design/Ideas/Reviews | 2 | 16th March 2008 09:31 PM |
| Amplifier Short Circuit | Menticol | Electronic Projects Design/Ideas/Reviews | 3 | 11th December 2007 05:10 AM |
| cal. short circuit power, in a series circuit. | north | Math and Physics | 37 | 7th March 2007 04:33 AM |
| possible (partial)short circuit ? | Thunderchild | General Electronics Chat | 8 | 14th September 2005 02:41 AM |
| short circuit idea | devigan | Electronic Projects Design/Ideas/Reviews | 17 | 24th May 2005 02:59 PM |
