hi
i am having problem how to hook relay into small motor. i have a motor that keep spin 'till the power is off. i need to hook a relay into the motor, how can hook it up. any one can hlep?
hi
all depends on how you want to power it. the most common is to put a signal on the coil of the relay (control signal for motor, turns it on and off) and then hook your supply and motor to the contacts of the relay. Depending on the config of the relay, hook them to the appropriate connections.Originally Posted by dave77
Hope this helps
Sceptre
