+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 43
Thread: High Voltage Op-Amps
  1. #16
    Frosty_47 Good Frosty_47 Good
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    399
    Quote Originally Posted by Hero999 View Post
    I still hope you sign up, we're a bit short of really active members who post loads.
    Then perhaps you've made a mistake with the simulation settings/models.
    Could you please post a scheenshot.
    Ok I signed up, here is a link to my first post:
    http://www.stop-microsoft.org/bbs/in...=12082.new#new
    As far as simulation is concerned, I will post a screen shot after I rebuild the circuit (didn't save sorry). This might take a while as I have no acess to internet from home (school time only).
    Thank you for your help!
    "The people who cast the votes don't decide an election, the people who count the votes do."
    -Joseph Stalin
  2. #17
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,976
    Great.
    I like your signiture by the way.
    Do you understand negative feedback in the booster now?
    I'll try simulating it in LTSpice.
    if I know the answer.
  3. #18
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    399
    Great.
    Yes, seems clear at this point.
    Thanks!
    Oh, and please visit Most random videos in chit chat section
    Most Random Videos
    I am sure you will find some funny videos there...
    Oh and there are a lot of quotes from Joseph Stalin. Some can be scary...
    “Death solves all problems - no man, no problem.”
    “A single death is a tragedy, a million is a statistic.”
    “When we hang the capitalists they will sell us the rope” (LOLZ I LOVE THIS ONE!)
    “If the opposition disarms, well and good. If it refuses to disarm, we shall disarm it ourselves.”
    "Education is a weapon whose effects depend on who holds it in his hands and at whom it is aimed.”
    "Mankind is divided into rich and poor, into property owners and exploited and to abstract oneself from this fundamental division and from the antagonism between poor and rich means abstracting oneself from fundamental facts”
    -Joseph Stalin
  4. #19
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,719
    Q5 and the diodes forms a current regulator that biases Q6 (a high gain common emitter amplifier).
    Hero, I think you had a brain fart here. Q6 is an emitter follower with a voltage gain of slightly less than one.
    Ron
  5. #20
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,976
    You're right and Q5 is the constant current load for it.
    I've just simulated it in LTSpice and it works perfectly.
  6. #21
    on1aag Good on1aag Good on1aag Good
    Join Date
    Aug 2006
    Posts
    512
    It won't work, when switched on two tiny black holes will
    be created and the rest of the board will be sucked in.
    The Vceo of the output transistors is only 140 and 150 volt.
    This is a perfect example of what stupidities you can do
    with a simulator.
    on1aag.
  7. #22
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,719
    I'm guessing that his transducer needs to be driven at ≈40kHz. The amplifier's response as drawn is about 1.3dB down at 40kHz. It also slews at about 12V/usec, meaning you can only get about 100V p-p at 40kHz out of it, even with no load. Sinewave simulation shows lots of distortion at 40kHz with 80V p-p output. The output of the LT1001 is a triangle wave under these conditions.
    If 40kHz is not the target frequency, then never mind!
    There are probably things that can be done to improve this performance.
    Ron
  8. #23
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,976
    It can be fixed by doing the following:
    • Use a faster op-amp.
    • Reduce R12 to increase the voltage gain of the buffer and put less strain on the op-amp, be careful too higher gain will cause oscillation.
    • Reduce the compensation cacitor values, again watch out for oscillation.
  9. #24
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,283
    Hi there,
    Hmmmm, did somebody say 120 volts at 1.2 amps? This is got PWM written
    all over it. Anything linear is going to eat up lots of power reproducing
    sine waves, unless square waves are acceptable of course, but then rise
    and fall times have to be carefully considered also. MOSFET's anyone?
    They are quite efficient for rectangular waves.
    In any case, calculate the power lost in the output transistors
    before deciding on a particular design and go from there.
  10. #25
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,976
    The problem is to build a decent class D amplifier, the switching frequency needs to be much higher the the bandwidth, for 40kHz the switching frequency would need to be 320kHz minimum.
    on1aag,
    Regarding the transistors: I just used the higest Vce transistors on LTSpice, I agree they need to be rated to at least 300V.
  11. #26
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,719
    Q3 is upside down.
    Ron
  12. #27
    Join Date
    Aug 2006
    Posts
    512
    Quote Originally Posted by Roff View Post
    Q3 is upside down.
    Maybe it's a symmetrical transistor ?
    on1aag.
  13. #28
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,719
    Quote Originally Posted by on1aag View Post
    on1aag.
    It turns into a low-beta transistor when you swap emitter and collector.
    .model 2N5401 PNP(Is=21.48f Xti=3 Eg=1.11 Vaf=100 Bf=132.1 Ne=1.375 Ise=21.48f Ikf=.1848 Xtb=1.5 Br=3.661 Nc=2 Isc=0 Ikr=0 Rc=1.6 Cjc=17.63p Mjc=.5312 Vjc=.75 Fc=.5 Cje=73.39p Mje=.3777 Vje=.75 Tr=1.476n Tf=641.9p Itf=0 Vtf=0 Xtf=0 Rb=10 Vceo=150 Icrating=600m mfg=Fairchild)
    The simulation oscillates when you place the transistor correctly.
    Ron
  14. #29
    Join Date
    Aug 2006
    Posts
    512
    Hi Ron,
    I noticed that too, at 1 MHz and above it looks a bit "playfull".
    on1aag.
  15. #30
    Join Date
    Oct 2006
    Location
    Canada
    Posts
    399
    Sounds good. I will do that along with a minor change to the emitter - follower circuit. I would like to use Darlington pair. Doing so I need to add 2 more diodes. The signal frequency will be varied from 6Hz - 60Hz so I probably won't have any issues with gain roll-off. I never dealt with switching amplifiers or components before so I doubt I can design a Class D amplifier at this point. So I will just stick to linear for now.
    Thank you for your help.
    -Joseph Stalin
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. Basic questions about Voltage and Amps...
    By max90272 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th May 2008, 03:42 AM
  2. Where can I find a ammeter that will measure high amps?
    By Nicksan in forum General Electronics Chat
    Latest: 12th August 2007, 09:31 AM
  3. Op-Amps at high frequencies
    By YAN-1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th August 2006, 02:19 PM
  4. [edit]: Voltage Regulator 1.5 amps using PWM
    By dinofx in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th January 2006, 05:51 PM
  5. High voltage, high speed measurement
    By Optikon in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th November 2005, 12:51 PM
Tags for this Thread
