Old 21st September 2008, 03:34 PM   #1
Default Bits are burning in my JA-S11 Amp
Yes, again this is about my JA-S11 JVC Amp like in my previos thread. Now I was trying to repair it, and I was going to test the output pins on the Sanken s-40w, but before I could, resistor 629 started to release the magic smoke.
Also the nearby transistor, a 2SB560, gets pretty warm too.
This is all in the attachment called schematic. I've circled the smoking resistor and warming transistor. I've also included a photo with the same parts circled, but the schematic should be of most help. The full service manual, including a PCB layout, is available here. (Note: You may need an account to view it - the account is worth it, though (free))
Okay, so obviously the amp is stereo, one chanel has a fault, so lets look at the component pairs. I tested all the main parts of each of the chanels (in the faulty area only) and found that the problem chanel's values matched the OK chanel - so I assume there is probably not a fault here.
What I do believe, though is that the problematic chanel's darlington chipset (a SanKen S-40, shematic included) is at cause. The problematic chaels S-40W was also the one that heated up a lot (with no input) like I described in my previous thread.
I have found a seller of S-40W's but I want to be sure, as, well, they're expensive
Thanks a lot
Bits are burning in my JA-S11 Amp-board.png   Bits are burning in my JA-S11 Amp-shematic.png
-michael11298
mike11298 is offline
Old 21st September 2008, 04:17 PM   #2
Remove the offending chip, and check carefully all other components in the faulty channel - anything in the DC loop could cause the output IC to fail again.
But the smoking resistor may just be down to the chip.
Old 22nd September 2008, 02:11 AM   #3
Thanks Nigel. Please excuse my noobiness, but what is the DC loop here? Is that the feedback circuit?
So I should buy a new chip then...
-michael11298
Old 22nd September 2008, 09:49 AM   #4
Everything between C603 and F601.
Yes.
Old 20th December 2008, 12:15 PM   #5
Thanks a lot
Hi, where did you find the electronic shema?
My JVC S11 amp, doesn't work actually. I know why, relay doesn't work, but i need the electronic shema to check it.
Thank you
Loic
stingniki is offline
Old 24th December 2008, 05:11 AM   #6
Uhhh the link is in the very quote you poseted. Signup for free and download the schematic for free...
-michael11298
amp, bits, burning, jas11
Burning hex to PIC Rusttree Micro Controllers 17 1st July 2006 03:11 PM
Burning Magnets windozeuser General Electronics Chat 9 19th November 2005 08:00 PM
Too much current burning my amp? schrodingerscat Electronic Projects Design/Ideas/Reviews 6 13th September 2003 11:24 AM
inverter mosfet burning hot Sarac Electronic Projects Design/Ideas/Reviews 15 9th March 2003 01:05 PM
Inverter Mosfets - Burning Hot Sarac General Electronics Chat 3 4th March 2003 05:11 PM
