Cheap alternative to hot air rework station?
  1. #1
    ArtemisGoldfish ArtemisGoldfish is offline
    Well, hot air rework stations are a little expensive (by expensive, I mean that I can't afford it.) Anyways, I was wondering if anyone has ever tried using a hot air plastic welding kit? I'm not looking to keep the host circuit boards in amazing shape or anything, I just want an easier way to remove DIP's and the like (irons just don't do it!)
    Linkohs.
  2. #2
    3v0 3v0 is offline
    Coop Build Coordinator
    If all you want to do is salvage parts from old boards a hot air gun will do the job. But it too easy to overheat the PCB which can be a bit on the smelly side so I do it outdoors.
    The plastic welder is only $20 less the then hot air rework from MPJA.
    Quote Originally Posted by ArtemisGoldfish View Post
    Linkohs.
    0
    BCHS/3v0's PIC C18 Tutorials
    Mondo Tech's Super Probe
    Brian Schmalz's USB Bit Whacker
  3. Thread Starter #3
    I don't have a hot air gun (I used to use a "power paint stripper", but it was powerful enough to set wood on fire from a distance, not to mention toast boards.) The MPJA one for 99USD looks good, all I really need is a rework station that has a smaller directed airflow, using a heat gun on a circuit board is like swatting flies with an elephant gun.
    0
  4. #4
    Externet Externet is offline
    Non hot air... use a plain soldering iron with an attachment tip that has 2 channel rows to fit the pins footprint pattern.
    http://www.geocities.com/BourbonStre...m/desolder.jpg
    Miguel
    0
    Abolish the deciBel !
  5. #5
    3v0 3v0 is offline
    From time to time you see DIY efforts to build hot air rework units. Often times an aquarium pump is used for the air and a soldering iron for the heat. I am sure it can be made to work if you get the right stuff and do a decent job of it. At one time I would DIY most anything and everything but I am slowly getting over that. The $100 unit looks good to me.
    0
which rework/hot air nozzles? the_doc735 General Electronics Chat 14 7th September 2008, 07:28 PM
Hot Air Rework JEXLI General Electronics Chat 2 30th April 2007, 04:10 PM
Solder Station crashNburn General Electronics Chat 6 9th November 2006, 05:08 AM
cheap Scope alternative Styx General Electronics Chat 2 9th August 2005, 01:07 PM
Help Needed about SMD Rework Station xpacer General Electronics Chat 0 16th July 2003, 02:19 PM
Page Time: 0.04867 seconds      Memory: 7,374 KB      Queries: 16      Templates: 0
