| In order the make transistor fully on, there must be 0V across the collector, this condition is called saturation. (from the book I read) what is fully on? what if there is 5V accross the collector? Tq. | |
| 'Saturation' for many BJTs is chosen where the base current is 1/10 of the collector current. At that point, the collector voltage (with respect to emitter) is in the 0.1 to 0.4V range depending on the data sheet. Other transistors are specified with a saturated beta anywhere between 5 and 500 (or more?). If there is 5V across the collector without any resistance, a lot of power is dissipated in the collector and the magic smoke comes out. | |
| Although the 1 to 10 base current to collector current ratio is a good one. I tend to go by the minimum beta on the datasheet, especially if I need to save power.
| Saturation = b-e voltage > c-e voltage. . .? | |
| That's a good definition of saturation.
__________________ Carl | |
| Yes, meaning that the collector-base junction is forward-biased. | |
| I've never looked at it like that but I suppose that's true.
| why dont you start a new post? a lot of discussion and none related to my question.. | |
Most have answered the question correctly. Its important to realise that in most transistor amplifiers/switching circuits there is a load in the collector between the voltage supply rail and the collector. If the current flowing thru this load is high enough ALL the supply voltage will be dropped across the load, so the collector voltage will be close to 0V. Does that help. EDIT: added a dwg
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 31st August 2008 at 01:00 PM. | ||
| | (permalink) | ||
Ideally the collector voltage with respect to the emitter would be zero when the transistor is in saturation but in practise we consider it to be fully on when Vbe>Vce. Quote:
Across the collector? With respect to what? I can only assume you mean with respect to the emitter, i.e. Vce. To answer your question, it depends on the supply voltage, if the transistor circuit is operating from 5V then we would say it's operating in the cutoff region (fully off) but if it were running from a supply voltage of say 10V then we'd say it's operating in the active region (neither fully on or off). http://en.wikipedia.org/wiki/Bipolar...s_of_operation
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | |||
| Thank you. | |
| most of them answered it correctly...with hero answer being accurate.... so i think no more fudging ovr this issue.... | |
| A really nice Difo! though it is a metaphore from a book!
__________________ When you Teach, You Learn Twice! Last edited by Muhammad89; 3rd September 2008 at 04:09 AM. | |
| Quick Transistor Question | skeeterb | General Electronics Chat | 8 | 3rd May 2008 08:35 AM |
| Transistor Question | ScuzZ | General Electronics Chat | 3 | 6th January 2007 02:15 PM |
| Transistor question | sandeepa | General Electronics Chat | 2 | 20th November 2004 12:22 AM |
| Transistor question | DirtyLude | General Electronics Chat | 16 | 21st July 2004 07:57 AM |
| transistor question | defcon31 | General Electronics Chat | 7 | 2nd January 2004 05:53 AM |
