Old 27th August 2008, 10:04 PM   (permalink)
Default Troubleshootng Power Supply
I bought a powered breadboard which is supposed to give me a regulated +5vdc 1Amp output, OR +15vdc variable / -15vdc variable output. The +5 regulated seems to work fine, but the +15/-15 is totally out of wack..
Here are my measurements with a multimeter, no load conditions:
+5 to ground = +4.96 vdc
+15 to ground = (pot turned full left) -0.16 to (pot turned full right) +14.97 vdc
-15 to ground = (pot turned full left) -14.93 to (pot turned full right)-14.93
As I turn the pot from full left toward the center, the voltage decreases until I get to the center, when it will hit -5.87 vdc, then as I continue to turn toward the right past center the voltage increases again until I am back at -14.93 vdc.
-15 to +15 = (both knobs left) 14.7 vdc. Rotatinig +15 knob to the right increases voltage until max out at 29.8 vdc. Leaving the +15 knob at max, I move to the -15 knob and begin rotating it to the right, voltage decreases until I get to the center position, at which point it is at 21.1 vdc, then continuing to the right the voltage increases until max out at 29.8 vdc.
I don't think it is supposed to function this way, though I am known to be wrong about these things I expect the -15 to ground to give me 0 vdc when turned left, then decrease until max at ~ -15vdc. Does anyone have an idea what may be the problem here? Voltage regulator? Possibly something else? Thanks in advance..
0x00x0 is offline
Old 28th August 2008, 01:42 AM   (permalink)
may i suggest youto post the diagram of your project, this will help us analyze the problem.
L2jsikan is offline
Old 28th August 2008, 01:55 AM   (permalink)
Yes, and there might be an internal adjustment to get rid of the -0.16v.
With a diagram it might be obvious that one open connection will cause your symptoms.
There are a lot more possibilities if it is a short from some point to some other point.
Willbe is online now
Old 28th August 2008, 02:52 AM   (permalink)
When measuring the -15 volts, be sure you observe the correct polarity with the probes of your MM.
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 28th August 2008, 04:11 AM   (permalink)
Sounds like the pot for the -15V supply is wired wrong. Almost like they mixed up one of the legs with the wiper. The +15 and +5 supplies seem OK to me.
kchriste is offline
Old 28th August 2008, 04:45 AM   (permalink)
So you have a power supply with two terminals for +5V and 3 terminals for +15/-15V that share a ground. Is this correct?
What do you mean by OR?
"I bought a powered breadboard which is supposed to give me a regulated +5vdc 1Amp output, OR +15vdc variable / -15vdc variable output."
Is there a switch to change between the power supplies?
It doesn't sound like a ground problem. Can you provide a picture for more details?
"Remember, you're special.....just like everyone else."
rezer is offline
Old 28th August 2008, 08:36 AM   (permalink)
This is what I have:
http://www.mpja.com/prodinfo.asp?number=15614+TE
0x00x0 is offline
Old 28th August 2008, 09:17 AM   (permalink)
Breadboard with built-in multi-output power supply.
Features 4 power supply binding posts, 5 Distribution strips, 3 Breadboard panels (total 2400 points), one +5VDC @ 1A supply, one 0 to +15VDC @ .5A supply, one 0 to-15VDC supply all mounted in a metal case. Includes 6ft. IEC power cord.
See above quote from the breadboard manufacturer.
They left out the current rating for the -15V supply, for some unknown reason.
L.Chung
eblc1388 is offline
Old 28th August 2008, 04:17 PM   (permalink)
If not as above- a manufacturing defect- and it worked at one time, then the first thing I would do is try to clean, with spray, the pot which didn't work well.
BeeBop is online now
Old 28th August 2008, 04:47 PM   (permalink)
It is basically brand new, and has done this ever since I 1st removed it from its box. I had it for several months before I even opened it, so sending it back for replacement is not an option at this point..
0x00x0 is offline
Old 28th August 2008, 05:26 PM   (permalink)
By left you mean CCW?
You mean -14.7v?
I would expect 15v + 5.87v = ~21v; so far so good.
So do I
I assume this breadboad uses two ea. heat-sinked three terminal regulators. Can you copy the numbers off of these chips?
Your measurements were taken at no load?
From the specs, I assume the -15v is also supposed to deliver a half-amp? It's not specifically mentioned.
Please post a photo of the component side of the circuit board, and
please post the voltages [with respect to ground] on all three -15v regulator pins and
all two or three pot terminals with the -15v pot at each extreme, and at the pot setting that gives -6v.
Do you have a scope? If you do, make the measurements with a scope.
Old 28th August 2008, 05:51 PM   (permalink)
OK, then it probably is a manufacturing defect. I would check this first:
Likely, noting the price, it probably uses LM317+LM337 regulators.
solar power supply + backup power mabauti Alternative Energy 9 21st March 2008 06:22 PM
ATX power supply and Power Dremel jimmyboy General Electronics Chat 1 1st July 2007 03:10 PM
AT power supply to power Laptop. ArtemisGoldfish Electronic Projects Design/Ideas/Reviews 6 2nd March 2007 05:39 PM
Power Supply Experts!! Need help with KEPCO Labs Power Supply headbuttking2 General Electronics Chat 1 24th October 2006 02:05 AM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
