| You know that the voltage of a load cell is relatively small... can I connect the load cell directly to a PLC??? or Shall I make an amplification stage ??? | |
You will require to amplify a load cell signal before using it with a PIC. A LC has an output in the order of 0 thru 10mV or 20mV at full load. If you use the PIC's adc with the internal 5Vref, the LC signal will require 5000/10 = *500 gain for the max adc value. What resolution in weight are you planning, also whats the max weight.?
Does the PLC you are using have any ADC inputs.?
| well, not an integrated ADC .. but I will use an ADC module .... it has 12 bit resolution ( values from 0 to 4095 ) .... the load cell's output is 2mv/v | |
Is that 2mV/Volt or maximum output.? What the weight range of the Load Cell.?
| No this is the output voltage per each volt of excitation voltage ... the cell weight range is from 0 to 100 kg | |
So IF the Vx=12Vdc then the 100kG FSD would be 24mV. The Vext should be marked on the cell.? Which external ADC do you plan to use.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 27th August 2008 at 02:14 PM. | ||
| as I've told you before I'm planning to use an ADC module .... it has 12 bit resolution ( values from 0 to 4095 ) | |
| | (permalink) | ||
hi, Thats what I said Quote:
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |||
| the model is Al-1116 .... it's a product from ALTUS company This is the website of the company: www.altus.com.br | |
I have downloaded the datasheet. I would suggest the 0 to +5V input option. The LC output will require to be amplified from its 2mV/Vx upto 0 to +5V, also a ZERO and SPAN control pot for the amp. Are you using all 8 input channels.?
| Thanks Eric ... Why do I need to amplify the signal ? ... The LC output is from 0 to 2mv/vx this values are inside the range 0 to 5v | |
That means to get a count of 4096 requires a +5V input. If you say had a 10mV input the all you would get from the ADC is 0.01 * 4096 =40 [40.96] counts,,, which is no use, the resolution is far too low. If for example the LC had a 100Kg weight on it and gave say 10mV out, then the LSB of the ADC would be 100Kg/40 = 2.5Kg Do you follow OK.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 28th August 2008 at 08:32 AM. | ||
| ok eric ... What type of amplifiers can be efficient to use with PLCs?? | |
| 3 Wire Load Cell question | MrSeaton | Electronic Projects Design/Ideas/Reviews | 34 | 1st October 2007 04:03 PM |
| Load Cell Simulator | DSGarcia | Electronic Projects Design/Ideas/Reviews | 10 | 24th July 2007 07:38 PM |
| load cell output? | neels | Micro Controllers | 3 | 19th May 2005 03:01 AM |
| Load cell solution | Oznog | Electronic Projects Design/Ideas/Reviews | 2 | 9th March 2005 06:40 AM |
| Digital Readout for load cell | hhc11 | General Electronics Chat | 1 | 2nd March 2004 11:17 PM |
