Old 26th August 2008, 07:44 PM   (permalink)
Default Charging a battery using another battery
I have a 6V battery and I'm wondering if I could charge my mobile phone's 3.7V battery using it. Is it as simple a case as just connecting the + of the 6V to the - of the 3.7V and the same with the other terminals? Or would I need to use resistors?
Also, would it work if I took the charger adaptor and just connected the + and - of that to the 6V battery and then plugged it into the phone?
Or would all this just result in a massive explosion?
Tetz is offline
Old 26th August 2008, 07:57 PM   (permalink)
I wouldnt even think about it, some of these mobile batteries are not forgiving.!
For starters you need a voltage regulator and some means of limiting the current.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 26th August 2008, 08:02 PM   (permalink)
Put the 6V battery into your phone and connect it to the 6V battery, you might need a voltage reaulgtor but the chances are it'll be alright without because most phone power supplies aren't regulated.
Screen name: Aloone_Jonez
Hero999 is offline
Old 26th August 2008, 08:06 PM   (permalink)
I know that mobile phone chargers really just provide a DC current, so I figured a 6V battery wouldn't be much different. I believe that the voltage regulator and other charging mechanisms are in the battery, so connecting the 6V by the connector should theoretically work. I might try it on an old phone first!
Also, while on this topic, is it as simple a case with USB chargers? I know USB ports provide 5V, but I don't know if it's just a basic voltage or if there's more to it.
Tetz is offline
Old 26th August 2008, 08:10 PM   (permalink)
That isn't true, the regulator mechanism is in the phone, not the battery.
Hero999 is offline
Oops, that's what I meant to say! I got carried away with the word battery!
Tetz is offline
Old 26th August 2008, 08:24 PM   (permalink)
Thirty five years ago "George" came to class with a stained shirt full of holes that were made by battery acid [since the shirt was still 99.9% "there", why not wear it to class???].
I asked him what had happened and told him that even I knew that he would not get a woman while he was dressed like that.
He said he was making a go-kart out of a starter motor and four car batteries and he accidently wired one battery in backwards.
Willbe is online now
Old 26th August 2008, 08:34 PM   (permalink)
Hm, that doesn't sound terribly good! I suppose messing around with batteries isn't a great idea. I was just trying to think of a way to charge my phone next week since I won't be near a socket for quite a few days ... and I'll be needing to use my phone quite a lot too. But replacement batteries are just so expensive ...
Tetz is offline
Old 26th August 2008, 08:45 PM   (permalink)
Funny you should mention this.
Here in RSA you can buy a cellphone charger based on batteries, completely portable.
I do not have the exact spec, but must maybe look into it for you.
arrie is offline
Old 27th August 2008, 01:45 AM   (permalink)
Don't ever try to charge a 3.7V lithium battery unless you have a proper charger circuit for it. It will catch on fire if it is incorrectly charged.
audioguru is online now
I'm Charging my Battery watzmann General Electronics Chat 4 14th September 2007 01:34 PM
New Li-ion Battery charging VictorPS General Electronics Chat 12 13th April 2007 08:25 AM
battery charging. manz Electronic Projects Design/Ideas/Reviews 9 8th July 2006 03:04 PM
SLA battery charging? czwalga Electronic Projects Design/Ideas/Reviews 4 13th April 2006 07:15 PM
Battery Charging Kingpin094 General Electronics Chat 3 11th July 2004 04:44 PM
