| Hi all, I have been working on a small circuit the last few days which is designed to be an RGB Led Controller. I am no electronics expert and have been learning as I go, but I've hit a problem with my finished board and can't figure out what is happening.. The circuit was built using the diagram attached, and everything is indentical except I had to use IRFZ44N fets as I could not source IRFZ14 locally.. Now to the problem.. all the leds on the board work (they are just there for testing so you don't have to attach anything to the outputs) but I get very low voltages from the actual outputs - all of them are giving around 0.02v - 0.08v, it should be more like 12v! I have metered the voltage at the gate of the fet and they are all around 2.02v Have I done something wrong or has the change of components screwed something up ? Thanks! | |
| We need your schematic. Your gate voltage is way too low to turn on the IRFZ44. John | |
| Hi John, Thanks for your reply. Is that referred to as the 'gate threshold voltage' ? I attached the schematic I used to make the circuit in the original post; http://www.electro-tech-online.com/a...t_crontrol.gif Is it something different you need ? Many Thanks Neil | |
| | (permalink) | ||
No. Gate threshold is where the gate starts to turn on, and can explain why your output is so low. You need to fully turn on the gate to have it act like a switch. For the Mosfet you are using, that is approximately 10V. Quote:
John | |||
| | (permalink) | ||
I spoke to the person who drew that PCB layout yesterday and they mentioned I should never see higher than 5v at the gate as its fed 5v from the PIC.. If that is the case then will I have to replace the IRFZ44's with 14's ? Or is there anything I can modify to make it work? Quote:
I don't think there is a schematic with symbols etc.. available for the exact layout I used, its design originates from here if its any help?; http://users.skynet.be/RafkeP/tutori...circuit_v2.jpg but that design is missing the fets. Thanks Neil | |||
Are you sure it was not an IRLZxx? The "L" is low voltage and will turn on at 5V. John | ||
| Hi Swifty, The leds are connected accross the gate-source junction of the mosfets. This will prevent the fets to be driven. You should at least get 4 to 5 volt drive to get anything out of the fets. Check the Vgs/Id characteristic in the datasheet. You need to remove the leds to get the thing working! The output voltages will always be zero because the drains are connected to the outputs, this means that you need to connect the external leds with the anodes to the + 5 volts (com ?) and the cathodes go to the drains of the fets. And don't forget to put a resistor in series with the leds to limit the current, otherwise the fets will fry the leds. Have much fun ! on1aag. | |
| Thanks to both for your help. John, the info for making the board definatley states IRFZ not IRLZ.. on1aag, thanks for your input - I _think_ I now understand what you are saying; If I look at the datasheet for the fets it says the threshold is 2 > 4v so above 4v the fet will begin to output ? And the fets are only getting around 2v because ~ 2-3v are being sucked by the leds which are inline with the supply to the fets? Hopefully I have understood that correctly Thanks! | |
| Ok in answer to my own question I guess I understood things correctly! I have just desoldered the +ve leg from one of the LEDs on the board and I now see 12v at the output for that channel! Thank you so much o1aag! | |
| Hi Swifty, With only 5 volt drive these fets can sink up to 500 mA, so don't push it. If you want more you'll need to replace them with logic level fets and . . . those are expensive. You can get some for free if you've got old motherboards. on1aag. | |
| The gate threshold voltage is 2V to 4V. The drain current at the threshold voltage is only 0.25mA which is barely turned on. If you find a Mosfet with a 2V threshold voltage then it will conduct many Amps with a 5V gate to source voltage. If you find a Mosfet with a 4V threshold voltage then it won't conduct much current with a 5V gate to source voltage. The Mosfets are guaranteed to conduct many Amps with a 10V gate voltage.
| LM723 IC with Mos-Fets output??? | The-dude | Electronic Projects Design/Ideas/Reviews | 16 | 27th October 2008 03:37 PM |
| P channel FETs vs N channel FETs for LED Matrix applications ?? | tdg8934 | General Electronics Chat | 3 | 9th September 2007 06:17 PM |
| ac output from dc power supply | aurosunil | General Electronics Chat | 4 | 11th August 2005 12:21 PM |
| Op - Amp with power output stage | andy257 | General Electronics Chat | 3 | 26th May 2004 06:25 PM |
| dc power supply fets...which, where, why? | seaball | Electronic Projects Design/Ideas/Reviews | 3 | 5th August 2003 10:05 PM |
