Old 26th August 2008, 09:44 AM   (permalink)
Question Sensing small voltage changes
The voltage signal from my radio receiver changes from 0.15V when switch is off to 0.3V when its on. I want to operate a 5V relay which switches on and off along with this switch. How can this be achieved?
Gaussx123 is offline
Old 26th August 2008, 09:53 AM   (permalink)
Hi Gauss, and welcome to the forum.
Which voltage signal? Is this a clean on-off signal (it doesn't sound like it) or is it the output on e a headphone or line out?
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 26th August 2008, 09:58 AM   (permalink)
Thanx. No its the signal from my FUTABA radio receiver on my plane. Its actually the landing gear switch. It is a PWM signal with the pulsewidth changing from 1ms to 2ms when I operate the switch. But I also noticed that the voltage across the signal and the ground leads changes the way I have mentioned. I want to use the voltage change directly instead of change in pulsewidth.
Old 26th August 2008, 10:03 AM   (permalink)
Is that voltage measured with a DMM? If so you are probably just seeing the average voltages as the PWM's duty cycle goes up.
It is probably possible to trigger just on the average voltage change, but I think it would be easier just to use the PWM output as it's intended to be used.
Torben
Torben is offline
Old 26th August 2008, 10:11 AM   (permalink)
Ya I tried to do that, I asked my professor and he gave me this circuit. I got an IC 7413 for the schmitt trigger but it is a 4-input device and I am not able to figure out how to use it. I have attached the document here. Also he has mentioned that I may have to use a flip flop but hasn't mentioned which one to use. Can you help me?
Old 26th August 2008, 01:46 PM   (permalink)
Look at this option.
EDIT: dwg edited to make clearer.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 26th August 2008, 03:42 PM   (permalink)
I am a bit confused now..Are the 4013 and HEF4013 u have indicated the same or are they different? And what are the components that you have indicated in blue and what are their values? Also what's this one shot and what is the input to the one shot implementation circuit given in Page 3 of the file I have attached. Can anyone give the whole circuit in one piece..Also help me in using IC7413 because it has 4 inputs..
Old 26th August 2008, 03:51 PM   (permalink)
A HEF4013 type 'D' flip flop has two identical FF's in the same plastic body.
The Res and Cap are the monostable timing components.
A one shot is a monostable.
A 7413 ic is a quad dual input Schmitt NAND gate, why did you ask for a 'D' type FF.??
Eric
PIC tutorials:
imulate a small Voltage Drop Out with MOSFET vs. parasitic capacitances dirkdiggler2oo2 Electronic Projects Design/Ideas/Reviews 6 22nd December 2006 03:30 PM
low cost sensing low voltage AC justDIY Electronic Projects Design/Ideas/Reviews 22 6th November 2006 02:22 AM
Need help--->Voltage sensing, then sendng circuit adodd Electronic Projects Design/Ideas/Reviews 5 22nd April 2006 12:36 AM
sensing low voltage AC at varying frequencies Neil E. General Electronics Chat 7 9th March 2005 06:27 PM
Reducing Voltage for small motor control DirtyLude Electronic Projects Design/Ideas/Reviews 6 18th April 2004 10:29 PM
