Old 26th August 2008, 04:50 AM   (permalink)
Default IV curve of zener diode
let said i have got a zener diode in series with 2 resistors.
What can i observe from the IV curve with resistors and the IV curve without resistors?
Please advise. Thanks.
shermaine is offline
Old 26th August 2008, 08:06 AM   (permalink)
hi shermaine,
You could observe, while applying various voltages across the resistor/zener pair:
The reverse voltage drop across the zener and the effect of connecting resistive loads across the zener.
The current thru the zener
The body temperature of the zener
then plot the results on a graph.
Without a series resistor you will most likely 'observe smoke', dont do it.
EDIT: It would be a good idea to get the datasheet for the zeners you are testing.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 27th August 2008, 02:13 AM   (permalink)
A low voltage zener diode is a lousy voltage regulator. Its voltage changes a lot when its current changes and its voltage drops as it gets warm.
A high voltage zener diode is also a lousy voltage regulator. Its voltage changes as its current changes and its voltage increases as it gets warm.
A 5.6V to 6.2V zener diode is good. Its VI curve is allmost a vertical line which is good voltage regulation and temperature changes have a very small effect.
audioguru is offline
Old 27th August 2008, 11:36 AM   (permalink)
You could add a current regulator but by the time that you may as well have used a real voltage regulator like the LM317.
Screen name: Aloone_Jonez
Hero999 is offline
LED vs Zener Diode 8899 General Electronics Chat 11 10th July 2006 08:40 PM
zener diode jin29_neci General Electronics Chat 2 10th August 2005 11:15 AM
Zener diode Vinit_dhulla General Electronics Chat 1 15th April 2004 10:16 PM
Zener Diode P\N ? Clinton General Electronics Chat 2 19th January 2004 02:15 AM
Zener Diode P\N ? Clinton Datasheet/Parts Requests 2 18th January 2004 09:47 AM
