Old 25th August 2008, 11:28 PM   (permalink)
Default Reducing output voltage
I have a vending machine to which I want to attach a water pump. Problem is the older machine only has a 110V output, while the newer water pump requires a 24V output. How do I 'step' this 110 to 24? Are there off the shelf solutions, or will I have to create a solution?
Many thanks,
Dion.
dion is offline
Old 25th August 2008, 11:38 PM   (permalink)
Would that 24v be AC or DC? If AC a transformer should do it
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 25th August 2008, 11:52 PM   (permalink)
That would be AC. Thanks.
dion is offline
Old 26th August 2008, 09:25 AM   (permalink)
Transformers to convert 110 or 220 to 24 VAC are very common. Low-voltage controls for machines (usually 1 HP or greater) use them. So, if you scrounge through surplus/junk yards you are likely to find one. John
jpanhalt is online now
Old 26th August 2008, 06:13 PM   (permalink)
How powerful is the motor?
24V is a pretty common voltage you should be able to get hold of one pretty cheaply.
Screen name: Aloone_Jonez
Hero999 is offline
Very basic question about reducing voltage kevinwilson General Electronics Chat 7 13th January 2007 10:50 PM
need help reducing voltage and current jclaudii Electronic Projects Design/Ideas/Reviews 17 5th August 2005 04:09 AM
reducing voltage.. manz Electronic Projects Design/Ideas/Reviews 4 1st June 2005 07:16 PM
Reducing voltage from 9 to 5 volts Pallen33 General Electronics Chat 55 16th July 2004 05:03 PM
Voltage Reducing coastergeekrtc Electronic Projects Design/Ideas/Reviews 6 27th April 2004 12:35 AM
