how can i make 220 and 1000 mocro menery coils (using ferrite core) for my battery desulfator project
What current do you require?
| | #3 | |
Start here: http://www.dave-cushman.net/elect/rmcores.html
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 26th August 2008 at 07:55 AM. | ||
i need it for 6 amp at least
Hi dimper129, I also want to make the desulphator. Only problem is winding the 220uH and 1000uH coils. Can you please tell me how to wind the coils? | |
| | #6 | |
Look thru these links. ![]() Coil Calculator - Single-layer and mutil-layer coil calculation in javascript Inductance Calculator Approximate Air Coil Inductance Calculator Coil Designer RADIO CALCULATIONS
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #7 |
Hello, Interesting links. I do want to mention, however, that when winding an inductor with a magnetic core of any type there are many things to consider. Not only the initial inductance value, but also the change of inductance with dc current (sometimes called the 'incremental' inductance) and max current. This means that we need exact information about the core such as inside diameter, outside diameter, height, width, and material composition. Sometimes we can find info on the manufacturers site that made the core which makes it a little easier. Even so, sometimes problems come up, such as core saturation. Core saturation occurs when the current goes too high, and this causes the cores magnetic properties to drop to near zero. What this means to the circuit is that we start out with a core with very good mag properties and we end up with only an air core. This causes the inductance to change quite a bit, and this means the impedance decreases drastically and that means the circuit draws too much current. To help the situation, sometimes we can insert an air gap into the magnetic path. This helps to prevent saturation, but means the overall inductance comes down, and this means we have to add more turns of wire. As we add more turns of wire we decrease the coils ability to handle higher current because the core saturates even more easily, but because of the air gap we have overall increased the coils ability to handle higher current. Eventually however we might fill up the cores inside diameter so that no more wire can fit on that core, and so we find that we can not even use that core, so we have to go to a larger diameter core. This is a bit hard to acheive without some sort of procedure, but it is in fact doable. The real problem though is how to form the air gap. If we use a ferrite toroid core we would have to cut with a grinder or something, and try to get the gap to be the right width. This is very hard to do unless you are a core manufacturer with the equipment to do this kind of thing on a regular basis. There are however, other types of cores that can be used that come in two parts...we simply provide some insulation material to form a gap, and that gets us there too, provided we selected the right size core to begin with. There is a better way however, that gets us there much quicker. That is, to simply *purchase* a coil that is already made to fit the specifications. Since there are many many coils that can be found at online parts stores this is the fastest and easiest way to do it. The only thing we have to know now is the coils inductance, how much of a change in inductance is tolerable, and how much dc current would be flowing, and the max current. We could look up come coils on some parts store sites and find a coil that matches what we need, and order one. 100uH coils are very common, and so are 1000uH coils. It should be possible to find both of these somewhere online. | |
| | #8 | |
It might help us help you better.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | ||
| | #9 |
| desisn, inductor |
| Need help with inductor | Bryan76 | General Electronics Chat | 3 | 20th December 2006 04:00 AM |
| different between molded inductor and coil wound inductor??? | pepperman | General Electronics Chat | 1 | 23rd June 2004 07:19 AM |
| inductor Q | zachtheterrible | General Electronics Chat | 2 | 25th May 2004 08:32 PM |
| inductor | histrionic2002 | Electronic Projects Design/Ideas/Reviews | 2 | 10th May 2004 12:06 PM |
| inductor...HELP | cobra7_nz | General Electronics Chat | 15 | 9th December 2003 03:55 AM |
