| This is on the back of a 380-size DC motor, run by six D cells through a momentary switch. You can see the motor terminals soldered on each side near the bottom. The red and orange wires on top are the power input leads. ![]() Hosted on Fotki I hooked up 14.4v (12-cell NiMh pack) to get more speed out of it and it works fine, however it starts up slowly for the first half second. Is that what this board does? | |
| Your motor starts slowly because your 14.4V battery or the battery connector cannot supply the very high starting current. The weak battery probably will cause the motor to slow down too much when it has a load.
| Thanks, I guess I can leave it in then if it isn't limiting motor performance. I just need to assemble a new battery pack because the current ones are sort of mixed in cell capacity. What is the green thing labeled "W200"? | |
| It may be a termal circuit breaker or a termal fuse - It is in series with the motor. 200 sounds like 200ºF = 93ºC - a likely trip temperature
__________________ E Cerfoglio Buenos Aires Argentina | |
| I don't know. It looks like a current sensing resistor but it could be a fuse.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez Last edited by Hero999; 26th August 2008 at 08:03 PM. | |
| Don't EVER mix batteries like that, or even ones of different makes - one will always go flat first, the others will reverse charge it, and it will split leaking chemicals everywhere. | |
| Yeah I know, they were old batteries and I needed a high amp 14.4v source just to test the motor. The pack is an 8-cell and half of another 8-cell wired in series. I'm only on the first charge and I don't plan on recharging the pack after this. If I split the leads I can charge them separately but I plan on making a new pack from two identical 6-cell packs anyway. The local electronics toy store has 6-cell packs on clearance for 10 bucks but they only had one in stock. | |
| Here is the circuit..... What is the motor? | b_reagle | General Electronics Chat | 14 | 12th August 2008 04:52 PM |
| Need help with timer circuit for AC motor | TechSarge | Electronic Projects Design/Ideas/Reviews | 5 | 19th July 2008 12:58 AM |
| PWM circuit for a dc motor | burnsy007 | General Electronics Chat | 1 | 10th May 2007 09:36 PM |
| Motor shorting out circuit | bonxer | General Electronics Chat | 7 | 13th May 2005 07:24 PM |
| control circuit to motor circuit does it matter what wire i? | troyandash | Robotics Chat | 2 | 21st May 2004 12:26 PM |
