Experienced Member
Hi
Where is the best place to find/buy bench top power supplies? and at around what price (UK) would prefer to have a power supply rather than keep using 9v batteries :P Kane |
Experienced Member
have a scavenge around your friends or neighbours they are bound to have and old computer. The computer has a power supply inside that can supply 5 and 12 volt rails at very high currents.
www.winpicprog.co.uk - Great PIC language tutorials. |
Experienced Member
good plan!! :lol:
then all i need is a few different regulators to supply 9v and 6v what current rated ones should i use? (as you said they can supply very large currents!) Thanks Kane |
Experienced Member
Kane, It depends on your requirements. You may either use fixed or variable voltage type, 3 terminal regulators.Example,if you use a fixed regulator such as 7809, the out put current is limited to 1amp.On the other hand, a variable voltage regulator such as LM338K, you will be able to get voltages down from 1.2 to 32v max depending on you input voltage with a maximum current of 5amp. The LM 396K with voltages from 1.2 to 15v and a current of 10amp max. In high current applications it is essential to provide adequate heat sinking. Failure to observe this precaution may result in premature current limiting or output voltage foldback due to thermal shutdown.
Cheers!
\"Waste your money and you\'re only out of money,but waste your time and you\'re lost part of your life\" |
Experienced Member
ah ....it seems i understood wrong
i thought that because the power supply could give out that current...the regulator would use that current so i think i shall have a number of fixed 1A regulators Thanks alot Kane |
Experienced Member
what is the difference between a 1amp regulator and a 0.1A (apart from the obvious)
but why would a 0.1A be used in place of a 1A one? is there any other reason apart from price? Kane |
Experienced Member
You can get a .1A regulator in much smaller packages. For example you could find a .1A reg in a TO-92 (or tiny SOT-23) package instead of the larger TO-220 for a 1A.
For a hobbiest there really is no reason to use a smaller current rating. Another important thing to keep in mind when selecting a regualtor is the power dissipation. If you want a 3.3V supply regulated from a 12V supply at 1 Amp that is (12V-3.3V)*1A = 8.7W which is quite a bit of power to disipate in your regulator. 8.7W will reqire a fair sized heat sink on a TO-220 package or better. So don't just trust the current rating. Hope this helps. Brent |
Experienced Member
Thanks alot
((goes off the scroung a psu)) :lol: |
Experienced Member
Why don't you build your own bench power supply? Check this great
0-30 VDC STABILIZED POWER SUPPLY WITH CURRENT CONTROL 0.002-3 A here: http://www.electronics-lab.com/projects/power/003/ |
