+ Reply to Thread
Results 1 to 6 of 6
Thread: LED Data sheet!
  1. #1
    Muhammad89 Bad
    Join Date
    Aug 2008
    Posts
    82
    Default LED Data sheet!
    I am doing a project on Electriconics operated Traffic lights and in need of knowing a serial number of an LED that is supposed to work on 5v-DC?
    Any Suggestion would be appreciated!
    Muhammad89
    When you Teach, You Learn Twice!
  2. #2
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,057
    Any LED will work on 5V, you just need to add an appropriately sized series resistor.
    if I know the answer.
  3. #3
    Muhammad89 Bad
    Join Date
    Aug 2008
    Posts
    82
    Wink
    Quote Originally Posted by Hero999 View Post
    Hi Hero999,
    I thought of the use of a LED that was previously used upon a 12V-DC, but the light was little dim? what to do to make it fit the the %v-DC supply with full light, a resistor can be added if you suppose the applied voltage is greater than what it condones?
    Muhammad89
  4. #4
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,057
    Then the LED you bought obviously has a built-in series resistor.
    You can get LEDs with built-in series resistors designed for 5V operation but it's cheaper to buy one without and add your own series resistor.
  5. #5
    Muhammad89 Bad
    Join Date
    Aug 2008
    Posts
    82
    Excuse me!
    when I go to Electronics kit shops, they tell me they give you the LED based on the serial Number you request! most of them are shopkeepers and none of electronists!
    In short, can i get a serial number that matches what I look for ?
    Muhammad89
  6. #6
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,821
    Blog Entries
    13
    Quote Originally Posted by Muhammad89 View Post
    Excuse me!
    Muhammad89
    hi.
    Get the datasheet for the LED's that interest you.
    The sheet will state the forward voltage drop of the LED and its operating current in milliamps.
    To calculate the required series resistor do this sum:
    [Vsupply- Vled]/Led current.
    example: [12Vdc - 2V]/0.02 = 500R.
    Using this simple formala you can calculate for any LED.
+ Reply to Thread
  1. data sheet
    By avinaik in forum Datasheet/Parts Requests
    Latest: 29th March 2007, 03:06 AM
  2. ic data sheet
    By fundusam in forum Datasheet/Parts Requests
    Latest: 6th October 2005, 11:58 PM
  3. LCD data sheet
    By andrew2022 in forum Datasheet/Parts Requests
    Latest: 24th August 2004, 09:56 PM
  4. Need Data Sheet For LCD
    By dde2004 in forum Datasheet/Parts Requests
    Latest: 2nd July 2004, 08:11 AM
  5. Data sheet
    By srfr in forum General Electronics Chat
    Latest: 11th March 2003, 08:34 PM
Tags for this Thread
